Canonical transformation vs symplectomorphism
The discussion revolves around the relationship between canonical transformations and symplectomorphisms in the context of phase space and symplectic geometry. Participants explore the definitions, interpretations, and implications of these transformations, particularly focusing on their active and passive interpretations and the challenges posed by mapping points outside of a coordinate chart.
  • Some participants assert that canonical transformations are essentially symplectomorphisms that preserve the symplectic form, with differing interpretations of their active and passive roles in phase space.
  • There is a question about whether symplectomorphisms can map points outside of a given coordinate chart, raising concerns about how to interpret such transformations as coordinate changes.
  • One participant suggests that both active and passive interpretations of canonical transformations are valid, similar to how rotations can be viewed from different perspectives.
  • Another participant expresses confusion about the comparability of coordinates when points are described by different charts, questioning the validity of using transition functions in this context.
  • It is proposed that as long as the phase space is connected, there will always be a chart that contains both the original point and its image under the symplectomorphism.
  • Concerns are raised about the implications of using different charts for old and new coordinates, suggesting that this may complicate the understanding of the transformation itself.
Participants express differing views on the nature of canonical transformations and symplectomorphisms, particularly regarding their interpretations and the implications of mapping points outside of charts. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the importance of an atlas for the phase space when considering points that may lie outside a given chart, but there is no consensus on how to handle the transformation between coordinates in such cases.
lriuui0x0
I have read that canonical transformation is basically a symplectomorphism which leaves the symplectic form invariant. My understanding is that the canonical transformation is a passive picture where we keep the point on the phase space fixed and change the coordinate chart, where symplectomorphism is the active picture where we map the point to a different point using the same chart.
My question is couldn't symplectomorphism map a point outside of a chart? How do we make sense of such transformation as a coordinate change?
It's true that canonical transformations ##f## preserve the symplectic 2-form ##\omega## in the sense that ##f^* \omega = \omega## (that's the defining feature of such a transformation!). What does the question mean?
Citation please?
Usually, what I've read is that a canonical transformation can be interpreted in a pasive way (you are changing the label of the points) or in an active way (you are moving the points). Both are canonical transformations.
The same way that a rotation can be understood by saying that the points are fixed and the coordinate axes are rotating, or by saying that the points are rotating and the axes are fixed. They are both a rotation (and rotations are CT, btw).
I'm just trying to understand in what sense symplectomorphism is canonical transformation. My understanding is the following. When you have a symplectomorphism, that's an active picture of the transformation which maps a point on the phase space to a different point. If we have a coordinate chart that contains both the old and the new point, we see the new point will have a new set of coordinate values. This is how I translate the symplectomorphism to coordinate language, which I think is the active canonical transformation you talked about.
Now what happens if this function maps a point outside of the range of a chart? If this is the case, there's no common chart that contains both the old point and the new point, how do I know about the coordinate changes?
It is not something I've encountered in practice. But in any case, your phase space should be equipped with an atlas. If your point goes outside a given chart, you just use a different chart (from the same atlas) to label it.
Hmmm... I fee it's weird that the old & new coordinates are described by different charts, since they are completely not comparable that way. The transformation between the coordinates would not reflect the symplectomorphism itself, but also a random chart transition function.
So is the answer basically "you can always find a chart containing ##x## and ##f(x)## for the symplectomorphism ##f## that's worth considering"?
Well, yes. Given x and f(x) there is always a chart that contains both (as long as the phase space is connected)
But I also don't understand your objections to using transition functions.
