Cant get to grips with re arranging formulae
  • Thread starter Thread starter chaz699
    Formulae
28 replies · 5K views
chaz699
basically i can't get to grips with rearranging formulae
the question is
make U the subject
fv = uv
u+v
(uv is divded by u+v)
2. The attempt at a solution
i try at making them into brackets etc but i can't get to it
can someone show me step by step how to do it
thanks, much appreciated
Welcome to Physics Forums.
We won't show you how to do the question, but we will help you do it yourself.
When trying to make something the subject of a formula the best thing to do is to get it out of the fraction. How could you get (u+v) out of the fraction?
chaz699 said:
erm, put it on the other side of the formula?
Sounds good. So what does that give you?
chaz699 said:
fv(u+v)=uv ?
Looks good. What do you think the next step would be?
chaz699 said:
erm multiply out the brackets?
Sounds good.
chaz699 said:
so would it be
fu+fv+vu+v(squared)=uv
Not quite, note that to expand the bracket you would just multiply everything in the bracket by fv. Do you follow?
chaz699 said:
i don't quite understand that bit
Okay what is 2(3+4)?
chaz699 said:
answer is 14
Correct, which is the same as 2x3 + 2x4. Does it make sense now?
chaz699 said:
would it be FVU+FV(squared) = UV
Much better :approve:.
What do you suppose the next step is?
chaz699 said:
i actually have no idea
Try moving all the terms with u in onto the same side.
chaz699 said:
so then it would be
fv(squared) = uv-fvu?
Correct, now what would be the next step?
chaz699 said:
and then
fv(squared) = u
(v-fv)
Looks good to me
chaz699, your notation is a little difficult to follow because, in case you do not yet have a way to use mathematical typesetting, you have also not yet learned how to express things in purely text symbolism. Other than that, you need to practice some number properties operations which lead up to your current exercise. (they are often called, "Field Axioms" or "Properties of Equality". ) Are you by some great chance studying Beginning Algebra or Introductory Algebra? Are you studying Pre-Algebra?
im studying a level physics (after high school, before university)
i just find rearranging formula hard
From chaz699,
I am studying a level physics (after high school, before university)
Not sure what that physics course means, but that placement suggests what many might consider to be "introductory physics", requiring basic algebra, ability to use simple Trigonometry, but no use of Calculus; a physics course which does not count toward an engineering or science undergraduate degree. Even so, such an introductory course requires, absolutely requires basic algebra skills, so if you are weak as you seem, you need to thoroughly restudy Introductory and most of Intermediate Algebra BEFORE you study your current apparent Introductory Physics course.
As for typesetting to make your math expressions clearer, one of the Reply To Thread features will give you a set of tools which will let you perform some mathematical typesetting. See the icons above the message field; they give you various symbol control effects. Not all the best typesetting features are available, but you may be able to use TEX or LaTEX, or something.
Superscript: X2
Subscript: X2
