Castigliano's method for the deflection of a cantilevered beam
The discussion revolves around the application of Castigliano's method to determine the deflection of a cantilevered beam at its midpoint. Participants explore the derivation of the deflection formula and address discrepancies found when comparing analytical results with finite element analysis (FEA) outcomes.
  • One participant expresses curiosity about the deflection formula for a cantilevered beam using Castigliano's method, noting that it was omitted in their coursework.
  • The participant presents their initial derivation of the deflection formula, which leads to a result that does not match FEA findings.
  • Another participant references a previous thread discussing complex beam equations and suggests using bending moment and shear force diagrams to clarify boundary values.
  • The original poster suspects errors in the bending moment functions used in their calculations and acknowledges the omission of support reactions.
  • A later reply identifies a correction in the second bending moment function, leading to a revised deflection result that aligns with FEA outcomes.
  • One participant commends the original poster for identifying the error and successfully resolving the issue.
Participants do not reach a consensus on the initial correctness of the formula derived using Castigliano's method, but there is agreement on the corrected bending moment function leading to a consistent result with FEA.
The discussion highlights the complexity of deriving deflection formulas and the potential for errors in initial assumptions or calculations. The reliance on specific bending moment functions and the exclusion of shear forces are noted as critical considerations in applying Castigliano's theorem.
FEAnalyst
Hi,
it may look like a homework but believe me that it's not. Castigliano's method was omitted when I was attending mechanics of materials course at my university and now I'm catching up. Another reason why I want to solve this is that I'm just curious what's the formula for the deflection of such beam as it can't be found in the literature.
Anyway, here's a beam that I want to solve for deflection of middle point (B) using dummy force P:
And here's my solution:
$$M(x_{1})=-M$$ $$\frac{\partial M(x_{1})}{\partial P}=0$$ $$M(x_{2})=-M-P \left( \frac{L}{2}+x_{2} \right) $$ $$\frac{\partial M(x_{2})}{\partial P}=-\frac{L}{2}-x_{2}$$ $$y_{B}=\frac{1}{EI}\int_{0}^{\frac{L}{2}} M(x) \cdot \frac{\partial M(x)}{\partial P}dx=\frac{1}{EI}\int_{0}^{\frac{L}{2}} \left( -M-P \left( \frac{L}{2}+x_{2} \right) \right) \cdot \left( - \frac{L}{2} - x_{2} \right) dx_{2} = \frac{1}{EI} \int_{0}^{\frac{L}{2}} -M \cdot \left( - \frac{L}{2}-x_{2} \right) dx_{2}=\frac{3L^{2}M}{8EI}$$
It seems fine but I solved an exemplary case and used FEA to find reference solution. This way I found out that my formula obtained from Castigliano's method is not correct. Do you have an idea what's wrong here ?
Thanks in advance for your help
This is an interesting problem, I was involved in a thread some time ago where the goal was to derive a similarly complex beam's analytical equations here: Thread: Harder beam equation
The general integration method followed this form which seems to be about what you're doing as well:
Mech_Engineer said:
The last attachment I posted is basically a fully symbolic derviation of the beam bending formula using the integration procedure. MathCAD did all the heavy lifting for me in terms of symbolic manipulation, but it can at least give you an idea of what you're in for (a lot of work).
You'll end up having to split the beam into three sections, integrate three times for each section, and then solve a system of 9 equations with 9 unknowns at the end. It's not pretty. A pdf of the MathCAD sheet you'll be most interested in is attached to the following post:
https://www.physicsforums.com/showpost.php?p=1600375&postcount=19
The integration tree you'll need is as follows:
[tex]\nu''''=\frac{q(x)}{EI}[/tex]
[tex]\nu'''=\frac{V(x)}{EI}[/tex]
[tex]\nu''=\frac{M(x)}{EI}[/tex]
[tex]\nu'=\theta(x)[/tex]
[tex]\nu=\delta(x)[/tex]
With this in mind, I do find solving this sort of problem is easier if you lay out the bending moment and shear force diagrams for the beam to help define boundary values. Do you have any diagrams you could post, maybe that will help us find a potential discrepancy?
MIT Open Courseware: Bending Moment and Shear Force Diagrams
Thanks for reply. I think that the bending moment and shear force diagrams for this beam should look like that:
To be honest, I suspect that the error is somewhere in these two bending moment functions ##M(x_{1})## and ##M(x_{2})##. I omitted support reactions but I guess it's correct. Anyway, something may be wrong in the second function.
I ignore shear forces in Castigliano's method as I only want to account for flexural strain energy.
P.S. In the thread that you've cited different method was used. I want to utilize Castigliano's theorem as this is what I'm trying to learn but of course another method may provide correct solution which would be fairly helpful.
Ok, it seems that I've found an error - as I suspected that second bending moment function was incorrect. It should be ##M(x_{2})=-M-P \left( \frac{L}{2} + x_{2} \right)##. When you solve the rest with this corrected term the result will be ##y_{B}=\frac{0.125M L^{2}}{EI}=\frac{ML^{2}}{8EI}##. Now the results agree with FEA solution.
Nice catch and well done seeing it through to the finish line!
