Catenary cable with balloon: finding horizontal tension and height
11 replies · 3K views · last reply
mcastillo356
The exercise is about, concerned with the catenary. But, algebraicaly solved, some sketch was missing.
##y=y_0\,cosh{\cfrac{x}{y_0}}##
##y'=sinh{\cfrac{x}{y_0}}##
Statement
The vertical component of the force exerted on the balloon in the figure is ##500\,N##. The ##AB## cable has a length of ##70\,m## and a weight per unit length of ##q=5\,N/m##. Calculate the horizontal component of the force exerted on the balloon, and the height of the globe, assuming the system is in equilibrium.
Algebraic solution
As we know there are two points, ##A## and ##B##, we use the following notation for the stresses: ##T_A## and ##T_B##, and ##T_{A_x}##, ##T_{A_y}##,##T_{B_x}##,##T_{B_y}## for the horizontal and vertical components. We will also use the concept of length of arch. We will assume that the arch ##AB## belongs to a catenary with the following notation: ##y=y_0\,cosh{\cfrac{x}{y_0}}## respect a cartesian coordinate system with no origin at ##A## nor ##B##.
It is known that at any point of the cable, the vertical component of the stress is directly proportional to the length of the arch, ##s##, being the proportionality constant the weight of the cable per length unit, ##q##. Also, the horizontal component is constant.
So, ##T_{B_y}=q\,s_B\Longleftrightarrow{500=5\,s_B}\Longleftrightarrow{s_B=100\,m}##
Thus, ##s_A=100-70=30\,m##
$$s_A=\displaystyle\int_0^{x_A}\,\sqrt{1+[y'(x)]^2}\,dx=y_0\,sinh{\cfrac{x_A}{y_0}}\Longleftrightarrow{30=y_0\,sinh{\cfrac{x_A}{y_0}}}=y_0\cdot{y'(x_A)}=y_0\,\tan{20^o}\Longrightarrow{y_0=\cfrac{30}{\tan{20^o}}}$$
Thus, respect to the horizontal component of the force made to the globe,
$$T_{B_x}=T_0=q\,y_0=5\cdot{\cfrac{30}{\tan{20^o}}}=412.12\,N$$
Also,
$$\cosh{\cfrac{x_A}{y_0}}=\sqrt{1+sinh^2{\cfrac{x_A}{y_0}}}=\sqrt{1+\tan^2{20^o}}\Longrightarrow{ y_A=y_0\,\cosh{\cfrac{x_A}{y_0}}=y_0\,\sqrt{1+\tan^2{20^o}}=30\sqrt{1+\cot^2{20^o}}}$$
On the other side
$$s_B=\displaystyle\int_0^{x_B}\,\sqrt{1+[y'(x)]^2}\,dx=y_0\,\sinh{\cfrac{x_B}{y_0}}\Longleftrightarrow{100=y_0\sinh{\cfrac{x_B}{y_0}}}\Longrightarrow{\sinh{\cfrac{x_B}{y_0}}}=\cfrac{100}{y_0}\Longrightarrow{\cosh{\cfrac{x_B}{y_0}}}=\sqrt{1+\sinh^2{\cfrac{x_B}{y_0}}}=\sqrt{1+\bigg (\cfrac{100}{y_0}\bigg )^2}\Longrightarrow{}$$
$$y_B=y_0\,\sqrt{1+\bigg (\cfrac{100}{y_0}\bigg )^2}=30\,\sqrt{\cfrac{100}{9}+\cot^2{20^o}}$$
Knowing the ordinates of both positions, we compute the difference
$$h=y_B-y_A=30\,\sqrt{\cfrac{100}{9}+\cot^2{20^o}}-30\,\sqrt{1+\cot^2{20^o}}\Longleftrightarrow{h=41.876\,m}$$
Finally, the calculus that inspired the Geogebra file I've drawn is this:
If ##s_B=100##, ##l(AB)=70##, then
$$s_B\,:=\displaystyle\int_0^{x_B}\sqrt{1+[y'(x)]^2}\,dx=\displaystyle\int_0^{x_A}\sqrt{1+[y'(x)]^2}\,dx+\displaystyle\int_{x_A}^{x_B}\sqrt{1+[y'(x)]^2}\,dx\Longrightarrow{s_B=s_A+l(AB)}\Longrightarrow{s_A=100-70=30}$$
There goes. No preview.
Graph of a red catenary curve with its lowest point at A on the x-axis; point O lies on the left branch and point B on the right branch, with angles 28.5° and 20° at A and 57° between the tangent lines to the curve.
Diagram of a cable hanging in a catenary curve from point A at upper left, attached to a support, down to a circle labelled B at lower right. The angle at A is marked 20 degrees, and a vertical dashed line with an arrow below B is labelled h.
mcastillo356 said:
The vertical component of the force exerted on the balloon in the figure is 500N.
What force is this?
There would be three vertical forces on the balloon, no? The weight of the balloon, the buoyant force on the balloon and the vertical component of the force from the cable.
Since the system is in equilibrium, these are in balance.
The vertical component of the force from the cable would be downwards and must be less than the weight of the cable (unless the diagram is misleading, and ought to show the cable rising above its tether, not hanging from it).
The diagram is twisted to the right in the original post. It should have been like this:
Diagram of a curved cable hanging from a pivot at point A on the left, rising to a balloon at point B at the top right, with the cable making a 20 degree angle with the horizontal at A and a vertical dimension labeled h? between the two ends.
Ok, but that can only be in equilibrium if there is some other horizontal force, a breeze perhaps, on the balloon. So I assume the task is to find that force.
You have the right answer for ##T_{Bx}##, but it can be derived in three or four lines, without needing to know the equation for a catenary.
Your diagram appears to put both the anchor point, A, and the origin for the catenary equation on the x axis. This is not possible. Maybe it would be clearer either by making the diagram larger or distorting the scale.
How?
Lnewqban said:
How?
How? . . . indeed .
How are ##\displaystyle T_{By}## and ##\displaystyle T_{Ay}## related ?
How are ##\displaystyle T_{Ax}## and ##\displaystyle T_{Ay}## related ?
How are ##\displaystyle T_{Ax}## and ##\displaystyle T_{Bx}## related ?
SammyS said:
How? . . . indeed .
The axial tension of the rope at B must be equal to the axial tension of the rope at A plus the weight of the rope.
Diagram of a chain of four circles joined by a black line, with blue and magenta circles alternating, and red and blue arrows showing force vectors at the joints and circle centres.
Everything gets fixed, I mean well defined, if we set the proper function that suits the correct diagram, ie, ##f(x)=82.42\cosh{\cfrac{x}{82.42}}##. Provided a cientific calculator, ##x_A=29.37##, and ##x_B=84.44##; so we conclude
$$L=\displaystyle\int_{x_A}^{x_B}{\,\cosh{\cfrac{x}{82.42}}\,dx}\simeq{70}$$
Graph of a catenary curve in green passing through points 0, A and B, with labels l(0,A) = 30, l(A,B) = 70 and angle α = 20° on a black tangent line at A.
There goes, no preview
The forces can be derived without the equation for the catenary (as @haruspex stated), but that isn't the only objective.
The catenary equation (if given in the question statement) to solve the problem to get the height of the balloon is a "helper fact", but it should be derivable from first principles. i.e. you shouldn't have to know it- correct?
erobz said:
The forces can be derived without the equation for the centenary
catenary. Same etymological root as "chain".
erobz said:
The centenary equation (if given in the question statement) to solve the problem to get the height of the balloon is a "helper fact", but it should be derivable from first principles. i.e. you shouldn't have to know it- correct?
Interestingly, we could have been given the weight of the rope instead of its mass per unit length. The answer can still be found without assuming the rope is uniform, so no need to assume it follows a catenary.
Oh yes, a double misspelling. Fixed.
Yeah, I do see that.
I'm having a bit of trouble deriving the curve, ## y(x)## from first principles.
