Cauchy-Riemann Condition Verification for f(z) = z^3-5iz+√7
  • Thread starter Thread starter chwala
    Condition
The discussion revolves around verifying that the function f(z) = z^3 - 5iz + √7 satisfies the Cauchy-Riemann equations. Participants confirm that the calculations show both sides of the equations hold true, indicating the function meets the criteria. There is a suggestion to explore alternative methods, such as expressing f in terms of z and its conjugate, but direct verification is emphasized as the most straightforward approach. The conversation also touches on the harmonic condition, noting it is necessary but not sufficient for satisfying the Cauchy-Riemann equations. Overall, the verification process is affirmed, with a focus on the principles governing the equations.
chwala
Verify ## f(z)= z^3-5iz+√7## satisfies cauchy riemann equations.
seeking alternative method
## f(z)= (x^3+5y-3xy^2+√7)+ (3x^2y-y^3-5x)i##
##∂u/∂x = 3x^2-3y^2 = ∂v/∂y##
##∂v/∂x=6xy-5= -∂u/dy##
hence satisfies.
Likes Delta2
Your attempt appears correct. What was your question?
Why? Is there some reason that the work below isn't satisfactory?
hence satisfies.
Likes chwala
If you think about expressing ##f=u+iv## in terms of ##z## and ##\bar{z}## instead of ##x## and ##y##, it's easy to show that the CR equations say that ##\frac{\partial{f}}{\partial{\bar{z}}}=0##. So any function that depends only on ##z## will satisfy CR.
Likes FactChecker
There is a simple way to see it immediately if you know that the sums and products of functions that satisfy CR also satisfy CR. Constants and f(z)=z satisfy CR. Your equation is a combination of sums and products satisfying CR, so it also satisfies CR.
Likes chwala
why? i have shown that both sides of the cauchy riemann pde hold. that's a summary of my working, or you want to see the full working?
thats exactly what i did. i substituted for ##z=x+iy##
My method is correct, its not an attempt. I was proving or rather to show that the given ##f(z)## satisfies the Cauchy Riemann equations. I am simply asking for alternative ways of solving. regards,
Well as the Cauchy Riemann conditions are directly verifiable there's not much else you can do but directly verify them. There are consequential conditions like the harmonic condition:
\Delta u = \Delta v = 0
but while this is a necessary condition it is not sufficient. It may be satisfied for functions failing to satisfy CR.
[edit: oops for the typo... now corrected.]
Likes chwala
\Delt u = \Delta v = 0
...directly verifiable...thank you.
What you did is not the same as applying general principles. You don't have to do the messy calculations if the principles have been proven. You have to have proven the principle that sums and multiplications of functions satisfying CR will also satisfy CR. Then just state that your function is a combination of sums and multiplications of simple functions satisfying CR and apply the principle.
Likes chwala
kindly note pde means partial differential equations...just for clarity
  • · Replies 27 ·
  • · Replies 19 ·
