CFD Analysis of Solidification and melting of Ice
The discussion revolves around the computational fluid dynamics (CFD) analysis of the melting and solidification of ice within an annular cylinder. Participants are exploring the time required for the ice to melt and the temperature variation over time, with a focus on the modeling setup and results obtained from simulations.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant describes their CFD model setup in ANSYS, noting that the temperature variation with time results in a straight line, which they find absurd.
  • Another participant requests clarification on the methods used so far to understand the issue better.
  • A participant explains their choice of materials and parameters, including latent heat and temperature settings, and mentions that while the contour results are acceptable, the temperature vs. time graph is a horizontal line.
  • There is a suggestion to understand the underlying physics of the melting process before proceeding with further analysis.
  • A participant asks for the conceptual model of the melting processes involved, indicating a need for deeper understanding.
Participants do not appear to reach a consensus on the reasons for the unexpected results in the temperature variation graph, and multiple viewpoints regarding the understanding of the melting process are present.
Participants have not resolved the assumptions regarding the physics of melting and solidification, nor have they clarified the implications of the chosen parameters on the simulation results.
Researchers and practitioners interested in CFD modeling of phase change processes, particularly in thermal analysis involving melting and solidification phenomena.
mayanknitjsr
Hello,
I was doing melting and solidification of ice kept inside a annular cylinder. The temperature of inside wall of cylinder is 80 degree.
Now i want to analyse the total time consuming to melt the ice and plot temperature variation with time.
Actually i did analysis but the result i found is absurd and the variation of temperature with time comes straight line always.
Can you please suggest me.
Please tell us what you have done so far .
I created a model in ansys design modular. In fluent problem setup, i choose only Transient , melting and solidification option. In post processing The variation of temperature with time comes straight line. Although the contour of liquid fraction and temperature was acceptable.
For plot The temperature Vs time Graph, created a line parallel to X - axis.
  • Problem.zip
    Problem.zip
I couldn't open the zip file . Just give us a simple explanation of what you have done .
I choose material (Ice ) from fluent material list and add latent heat & solidus, liquidus temperature ( both 0 degree). Then patch the ice temp -2 degree inside the annular cylinder. inside wall of cylinder is at 80 degree while outside wall is adiabatic. Now start transient analysis.
In post processing, i created a line & plot a graph between temperature variation with time on that line.
You need to properly understand the physics of this problem before doing any more computer analysis .
What do you think is actually happening during the melting ?
What is your conceptual model of the processes involved ?
  • · Replies 45 ·
17K
  • Poll Poll
