Chain with 2 links lifted vertically - Force
7 replies · 3K views
mybrohshi5
A chain consisting of two links, each of mass 0.5 kg, is lifted vertically with an acceleration of 3.0 m/s2 upward.
The magnitude of the downward force exerted on the top link by the bottom link is?
F = ma
1 is the top link
2 is the bottom link
F1,2 = The force on 1 by 2
The Fnet on either of the two links is (0.5kg)(3m/s2) = 1.5N
so
Fnet = Fpull - Fg - F1,2
Fpull = 1kg(3m/s2) = 3N
so
1.5N = 3N - (.5kg)(9.8m/s2) - F1,2
F1,2 = 3.4 N downward
The answer is 6.4N but i don't understand why? where did i go wrong?
this is exactly what i did on a homework assignment and got it right but this is what i did on the test and i got it wrong since the answer is 6.4N not 3.4N like i got.
Thanks for any help
You didn't calculate F_pull correctly. Where's the weight force? You might want to check your new result by drawing a FBD of the bottom link.
I don't see how F_pull is wrong?
The only other thing i can think of doing to calculate this is to factor in the the acceleration of gravity?
and by weight force do you mean Fg cause i have that in there...
What i am really confused about is i used this same method on a mastering physics problem and got all of the answers right so i guess i got lucky on that. I really need to figure out how to do this right because I am sure something similar to it is going to be on my final.
You have got to draw free body diagrams to solve these problems. You noted that
But F-pull is the pulling force which must be greater than the weight of the links in order to accelerate them upward at 3m/s/s. Since the links weigh about 9.8 N, the pull force can't be just 3 N.
Again, you can also calculate F_1,2 directy by drawing a FBD of the botton link alone.
oh that makes sense.
ok so using my fbd of the botton link i have the force pulling it up which i believe is (3+9.8)(1) = 12.8 N in the upward direction
there is also the F_2,1 force in the upward direction (this is equal to F_1,2)
then there is the force of gravity of link 2 going downwards.
Does that seem right?
No. If you draw a FBD of the bottom link, there are only two forces acting on it, its weight down, and the F-2,1 force acting up. Use Newton 2 to solve for F_2,1. Don't put in forces that don't exist when you draw your free body diagram.
Oh jeez i feel stupid. That was a lot easier then i was making it.
so sum of the forces in the y = ma
Fy = 0.5kg(9.8+3)
Fy = 6.4 N
Thank you Jay
