charged particle motion in magnetic and electric fields
2 replies · 17K views
NutriGrainKiller
Problem 1:
A particle with mass 1.81*10^-3 kg and a charge of 1.22*10^-8 C has, at a given instant, a velocity v = 3.00*10^4 m/s jhat.
What is the magnitude of the particle's acceleration produced by a uniform magnetic field B=1.63T ihat + 0.980T jhat?
here is what i did:
knew to find the acceleration I needed to use a=QE/M, but since I didn't have E I had to find it. Used F(mag field)=Q*V*B*Sin(theta). I found theta from drawing the ijz axis and using trig, I got 59 degrees.
After I solved this I plugged it into F=QE to get E. Then plugged that into a=QE/M, and got an incorrect answer..not sure where I went wrong.
Problem 2:
A particle with charge 6.40 *10^-19 C travels in a circular orbit with radius 4.68 mm due to the force exerted on it by a magnetic field with magnitude 1.65 T and perpendicular to the orbit.
a) What is the magnitude of the linear momentum P of the particle?
b) What is the magnitude of the angular momentum L of the particle?
for a:
equations I used:
P=MV
R=MV/QB -> V= RQB/M
plugged 2nd into 1st, M cancelled, answer wasn't correct. eh?
for b:
not sure i know the equation for this problem...same as in classical physics?
thanks guys!
NutriGrainKiller said:
Problem 1:
here is what i did:
After I solved this I plugged it into F=QE to get E. Then plugged that into a=QE/M, and got an incorrect answer..not sure where I went wrong. Problem 2: for a:
equations I used:
P=MV
R=MV/QB -> V= RQB/M
plugged 2nd into 1st, M cancelled, answer wasn't correct. eh?for b:
thanks guys!
1) There's nothing wrong with your first problem except that you seem to be insisting there's an electric field. There isn't. The Lorentz force says:
[tex]\mathbf{F}=q\mathbf{E}+q\mathbf{v}X\mathbf{B}[/tex]. Since there is no E, the first term drops out. Then you calculated F, as you did. Now simply apply F=ma.
2) Part a) looks right, I'm not sure why things aren't working. What answer did you get and what does your book say? For part b) I would assume that you aren't being relativistic or quantum mechanical, so yes use the Classical formula.
-Dan
-Dan
thanks, figured the first one out!
for 2a i got 4.94×10−18
