Is the Operator L = d/dt + d^2/dx^2 + 1 Linear?
  • Thread starter Thread starter frenchkiki
    Linearity Pde
The operator L = d/dt + d^2/dx^2 + 1 is being analyzed for linearity. It fails the linearity test because when applying L to a sum of functions, the constant term from the operator disrupts the linearity condition. Specifically, L(u+v) introduces an additional constant term that does not match the expected output. The discussion highlights that the presence of the '+1' in the operator is crucial to understanding its non-linear nature. Therefore, L is classified as inhomogeneous and not linear due to the constant term.
frenchkiki
Check du/dt + d^2u/dx^2 + 1 = 0
L is a linear operator if:
cL(u)=L(cu) and L(u+v)=L(u)+L(v)
L(cu) = d(cu)/dt + d^2(cu)/dx^2 + 1 = c du/dt + c d^2(u)/dx^2 + 1 ≠ cL(u) = c du/dt + c d^2/dx^2 + c. So I found that it is not linear since it does not satisfy cL(u)=L(cu). However the solution tells me that it is. Can anyone spot my error?
Thanks
Are you sure the problem wants you to include the '+1' in the definition of the operator?
So that would be du/dt - d^2u/dx^2 = -1?
Then I have Lu = -1, L(cu)= d(cu)/dt - d^2(cu)/dx^2 = c du/dt + c d^2u/dx^2 = c L(u), L(u+v) = d(u+v)/dt - d^2(u+v)/dx^2 = du/dt + d^2u/dx^2 + dv/dt + d^2v/dx^2 = Lu + Lv, so it's linear and inhomogenous.
Thank you.
I think what Mute was suggesting is that the real problem you have with linearity is
the -1 . For d(u+v),you will end up with the constant term -1 , but the same
will be the case for each of du and dv .Then du+dv will have constant term equal to
-1 -1 =-2≠ -1
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
