Checking a u-substitution integral solution
  • Thread starter Thread starter EGill
    Substitution
6 replies · 2K views
EGill
I have attached a word document that shows all the work and equations.
Your help is appreciated.
[tex] x\left[\frac{dv(x)}{dx}+1\right]=\left[v(x)\right]^{3}+v(x)+x[/tex]
[tex]\mbox{ is correct, but the equation after it}[/tex]
[tex]f<br /> \left[\frac{1}{v(x)^{3}}+\frac{1}{v(x)}\right]dv=\frac{1}{x}dx[/tex]
[tex]\mbox{does not follow- you incorrectly manipulated the first equation.}[/tex]
[tex] \mbox{Try multiplying the x through in the } x\left[\frac{dv(x)}{dx}+1\right]\mbox{ term, and then try to separate the variables.}[/tex]
Thanks for the response. Took forever, but I have managed to do it correctly further along now.
I am still stuck at another point. The new attachment shows all my work again
You have an error.
I'm assuming that your work is correct up to where you said you're confident.
ln(u - x) - (1/2)ln[(u - x)2 + 1] = ln(x) + C
<==> ln(u - x) - ln[(u - x)2 + 1]1/2 = ln(x) + C
Now combine the two log terms on the left side using the property that ln(a) - ln(b) = ln(a/b).
Also, on the right side you have eln(x) + C becoming Cx. The first C is different from the second C. They're both constants, but they are different ones, so you should use a different letter or mark the second one to note that they are different.
[tex] <br /> ln\left[\frac{u-x}{((u-x)^2+1)^{1/2}}\right]=e^{ln\left[x\right]+c<br /> <br /> [/tex]
[tex] <br /> \frac{u-x}{((u-x)^2+1)^{1/2}}=Dx<br /> [/tex]
Would this be correct? Since C is a dummy variable i figured I could reuse it, but I see your point.
Also, this was my first time trying to type a formula into the reply. Whenever I hit preview post it would refresh, but the post would not reflect the changes in the equation area. I had to reload the page to get the post to reflect the changes in equation. Am I doing something wrong. Just trying to learn how to do it without word docs if it is just one equation.
That is correct. And no, you aren't doing something wrong inputting Latex code.. for some reason you have to refresh the page to view changes using preview post.
As I understand things, the LaTeX script is cached on your computer, so when you start a post and click Preview Post, the previous LaTeX script, if any, is displayed, not the script you just entered. This is a known problem. The workaround is to refresh the web page. That will display the right LaTeX script.
