Chemistry: Converting density to molar mass given other values.
12 replies · 50K views
LakeMountD
The density of a gaseous compound was found to be 1.23 kg/m^3 at 330K and 20,000 Pa. What is the molar mass of this compound.
PV=nRT
I don't think this is right but I assumed a volume of 1 m^3. So I used ideal gas law as follows:
n = (20,000Pa * 1m^3)/(8.314 (Pa*m^3/mol.K) * 330K) = 7.29 mol.
Then what I did was took density and multiplied it by the assumed volume of 1m^3 and got 1.23 kg/m^2. Then I took 1230g/m^3 and divided it by 7.290 mol. go get grams/mol*m^2. The answer was 168.72 but I can almost guarantee I am being retarded and overlooking something.
you can also use this equation
d = MP/RT
let me know what you get
I take it that is the molar volume formula?
The reason why I didn't use that is because it says in my book that the formula for molar volume (above) is used under STP conditions. Did I read that wrong?
Okay so d = MP/RT where M is the molar mass (or molar volume?)?
Sorry I just want to make sure. And thanks for the help guys. Like I said I saw that formula in the book but I thought it said it only applied at STP.
I ended up getting ~ 153g/mol
that's not what i ended up getting, is this that the correct answer in the book? i'll re-do my calc.
i'm off by ~ 15
I didn't get this answer either. I got the 168.72 g/mol that was given as the answer in the first post.
lol i didn't even notice the answer in the first post, it's correct tho. different method but valid and good.
gj!
Wait so I did it right the first time? I don't have the answer in the book, unfortunately it is an even numbered problem.
Why didn't the formula you told me work?
It should have. Double check your calculation.
M = d*R*T/P = 1230g/m^3 * 8.314 * 300k / 20,000 = 153.39 g/mol?
