Chemistry-Equilbibrium of NH4HS dissociation
  • Thread starter Thread starter hclark91
    Dissociation
The discussion revolves around the dissociation equilibrium of solid NH4HS into gaseous NH3 and H2S, focusing on calculations related to equilibrium constants, percent dissociation, and the application of Le Chatelier's Principle. Participants are addressing a homework problem that includes multiple parts requiring mathematical reasoning and conceptual understanding of chemical equilibria.
  • Homework-related
  • One participant calculates Kp for the dissociation reaction and finds it to be 0.1089 based on partial pressures derived from total pressure measurements.
  • Another participant attempts to determine the percent dissociation of NH4HS when placed in a flask, calculating it to be 13.5% under specific conditions.
  • A different scenario is presented where the initial pressure of NH3 is 0.2 atm, leading to a calculated percent dissociation of 5.3%, with an explanation referencing Le Chatelier's Principle.
  • Participants discuss the minimum mass of solid NH4HS required to establish equilibrium in a 2-liter flask, with one participant providing a calculation that results in approximately 2.752 g of NH4HS.
  • There is a correction regarding a numerical error in a previous calculation, with a participant clarifying a typo that affected the reported mass of NH4HS.
Participants generally agree on the mathematical approach to the problem but express uncertainty regarding specific calculations and interpretations of results. There is no consensus on the minimum mass of NH4HS required, as different calculations yield varying results.
Some calculations depend on the accuracy of initial assumptions regarding gas behavior and equilibrium conditions. The discussion includes potential arithmetic errors that may affect the final results, but these remain unresolved.
Students studying chemical equilibrium, particularly those interested in the dissociation of solids and the application of Le Chatelier's Principle in equilibrium calculations.
hclark91
I am having trouble with this question can anyone point me in the right direction?
Solid NH4HS dissociates according to the equation:
NH4HS (s) ---> NH3 (g) + H2S (g)
SOme solid NH4HS is placed into an initially evacuated vessel and when equilibrium is established there is still some solid NH4HS left and the total pressure is 0.66 at 25 centigrade
a) calculate Kp for the reaction:
P(NH3)=(0.66 atm)/2= 0.33 atm
P(H2S)=(0.66 atm)/2= 0.33 atm
Kp=P(NH3)*P(H2S)=(0.33atm)*(0.33atm)=0.1089
b) What percent of the solid will dissociate if 0.1 mol of NH4HS is introduced inot a l liter evacuated flask at 25 centigrade:
PV=nRT
2n=PV/RT=(0.66atm)*(1L)/(0.0821 L-atm/mol-k)*(298K)=0.0269 mol
n=0.0135 mol
0.0135 mol * 51g/1mol NH4HS= 0.6879 g NH4HS .1 mol *51g/1 mol= 5.1 g
0.6879g/5.1g=0.135
0.135*100=13.5% dissociated
c) what percent of the solid will dissociate if 0.1 mol of NH4HS is introduced into a 1 liter flask that initially contains only 0.2 atm of NH3 at 25 centigrade:
NH4HS ---> NH3 + H2S
I - 0.2 0
R - +0.33n +0.33n
E - 0.2+0.33 0.33
total: 0.2+0.66n
Kp=KxPt =0.1089=(0.2+0.66n)*(0.66atm)
n=0.053
0.053 *100= 5.3% dissociated
d) Explain the results from (b) and (c) above based on LeChatelier's Principle:
LeChatelier's principle states that a system at equilibrium when subjected to a disturbance responds in a way to minimize the disturbance. The initial stress of the pressure of 0.2 atm by NH3 needed to be minimized, so less of the reactant was dissociated. Less particles in the gas phase allowed shifts the reaction toward the reactants.
e) What is the minimum mass of solid NH4HS that must be added to a 2 Liter flask in order to establish equilibrium:
I am not really sure where to go with this part. I assume I must use the gas law to find out how many moles I will need then convert it to the
hclark91 said:
...e) What is the minimum mass of solid NH4HS that must be added to a 2 Liter flask in order to establish equilibrium:
That is exactly how I would approach it.
Using the method I thought would work I got
PV=nRT
(0.66atm)(2L)=n(0.0821L-atm/mol-k)(298k)
n=0.5395
0.5395x51g/1mol= 2.752g of NH2HS to obtain equilibrium
does this seem right??
Look at your arithmetic. Is this true?
0.06879g/5.1g=0.135
It looks like the answer is correct but there is this 0.06879 running around, which is a bit off.
sorry typo
PV=nRT
n=0.0135 mol
0.6879g/5.1g=0.135
I accidentyl put an extra 0 in 0.06879 it should be 0.6879. The rest of the numbers should be accurate after that correction
  • · Replies 19 ·
