Circular Motion 12th grade physics
2 replies · 6K views · last reply
cnfsdstudent
From the diagram above, solve for the reaction at point A. and the tension in the cable that is attatched at point C. Assume the bar is mass-less. Block B has a mass of 124 kg. The distance from point B to point A is 3.2m, from point A to point D is 1.3 m, and point D to point C 2.1 m. The cable attaches to the wall forming a 30 degree angle with the wall.
This is an equation with an attached pic from my high school physics class. It was a "just for fun" problem that the teacher does not expect us to be able to figure out, but I wanted to know if someone could give me some suggestions, I really have no idea. This is not for a grade, other wise I would have attempted it in a more vigourous level.
  • Worksheet diagram of a mass-less horizontal bar hinged at point D on a wall, with block B on the left, pivot support A below the bar, and cable C attached to the wall above D.
It is usually best to break up forces into their x and y components. I don't know if you have studied free body diagrams, but if yes, you should draw one of the 'block/ cable/ support at A' system, isolating it from the wall. Note that the horizontal and vertical components of the cable force are trig related. Then use the 3 equations of equilibrium to solve for the cable tension and support reactions.
Thanks so much! I will be working on this later on today, I will let you know if I have anymore questions
