Circular Motion of earth's orbit Problem
The problem involves Earth's circular motion around the Sun, specifically focusing on angular displacement and changes in velocity over a specified time period. The original poster presents calculations related to angular displacement and velocity, expressing confusion over discrepancies in the expected answer.
  • The original poster attempts to calculate angular displacement and velocity using provided equations, while expressing confusion over the acceptance of their solution. Other participants question the correctness of the original poster's calculations and suggest adjustments based on a similar problem.
The discussion is ongoing, with participants exploring different interpretations of the problem and the calculations involved. Some guidance has been offered regarding adjustments based on a referenced solution, but there is no explicit consensus on the correctness of the original poster's approach or answer.
There is mention of a discrepancy between the time periods used in the original poster's calculations and those in a referenced solution, which may be contributing to the confusion regarding the expected answer.
Selim Bradley
Hello everyone! Please, help me understand the following problem:
Earth's orbit around the Sun is nearly circular. The period is 1 yr = 365.25 d.
(a) In an elapsed time of 5 d, what is Earth's angular displacement? Solved!
(b) What is the change in Earth's velocity, Δv? Confused!
ω = Δθ/Δt
v = rω
I easily solved the first problem doing this: Δθ = (2π x 5 days)/365.25 days = 0.0860 rads
However, whenever I enter a solution for the second problem, the computer does not accept my answer, even though I'm solving it correctly. This is what I did:
First, I tried to solve for the angular velocity of the object. Since the computer wants the answer in meters per second, I converted Δt to seconds:
ω = Δθ/Δt = 0.0860121192 rads / (5 days x 86,400 sec) = 1.99x10^-7 rads/sec
Now, I substitute the distance between the sun and the Earth in meters and the angular velocity into v = rω to solve for v.
v = rω = (1.5x10^14 m)(1.99x10^-7 rads/sec) = 2.99x10^7 m/s
The correct answer, according to the computer, should be 2570 m/s.
What am I doing wrong? :cry:
Are you sure? That's similar to what I did, and that's not the answer, as I stated above.
its 2 days over there in the link i gave
and its 5 days in your case
just make the adjustments
sachinism said:
"just make the adjustments"
Well... I exactly followed their whole procedure. I'm getting the wrong answer still, the correct answer should be 2570 m/s. Thank you for the link though! Anyone else? Help :cry:
well may be the answer what u think is right is wrong :biggrin:
I am coming to that conclusion :approve:. However, before telling my professor, it would be nice if someone in the Physics Forums could check my work and OK it first, if that's alright. o:)
