Circular motion to projectile motion
18 replies · 3K views
ChetBarkley
A 100g ball on a 60 cm string is swung in a vertical circle about a point 200 cm above the ground. The tension in the string when the ball is at the very bottom of the circle is 5.0N. A very sharp knife is suddenly inserted when the ball is parallel to the ground to cut the string. What is the distance the ball will land after the string is cut.
T - mg = m(v^2/r)
delta y = v_y(t) + 1/2at^2
delta x = v_x(t)
So first I found the velocity of the ball at the bottom of the swing from the force equations, which I got to be 4.9 m/s and this is only in the x-direction. Then using the projectile motion for delta y I found time, which is 0.2s. Then using that time I found the delta x to be 0.98m.
I just want to make sure my work is correct and concise.
ChetBarkley said:
Homework Statement:: A 100g ball on a 60 cm string is swung in a vertical circle about a point 200 cm above the ground. The tension in the string when the ball is at the very bottom of the circle is 5.0N. A very sharp knife is suddenly inserted when the ball is parallel to the ground to cut the string. What is the distance the ball will land after the string is cut.
Relevant Equations:: T - mg = m(v^2/r)
delta x = v_x(t)
That's not what I got. I didn't, however, do any intermediate calculations. The ##0.2s## looks wrong. The ##4.9 \ m/s## looks right.
BvU said:
0.2 seconds?
:welcome:
Just wonder how you calculated that
So delta y = 0.2 and there is not velocity in the y direction once the string is cut, meaning v naught y is zero. So my equation looks like 0.2 = 0t+.5(9.8)t^2. Solving for t: t=sqrt(.2/4.9).
This statement makes no sense: "when the ball is parallel to the ground". Does it mean when the string is parallel to the ground (giving ##\Delta y=-2##) or when the ball is moving parallel to the ground (giving ##v_{0 y}=0##)? But it anyway cannot give both.
PeroK said:
How do you get that?
It's given in the problem
haruspex said:
This statement makes no sense: "when the ball is parallel to the ground". Does it mean when the string is parallel to the ground (giving ##\Delta y=-0.2##) or when the ball is moving parallel to the ground (giving ##v_{0 y}=0##)? But it anyway cannot give both.
It's when the ball is moving when parallel to the ground, giving ##v_{0 y}=0##.
ChetBarkley said:
So delta y = 0.2
Make a sketch. With a center at 2 m and a radius of 0.6 m, the lowest point is at 1.4 m. If it lands on the ground (also not stated in the prolem), how can you possibly 'calculate' a ##\Delta y## of 0.2 m ?
I imagine the idea was that ##200 \ cm = 0.2 \ m##.
PeroK said:
I must admit I always have to do a mental check to avoid confusing ##cm## and ##mm##.
Try furlongs and inches ...?:)
