What is the formula for calculating the circumference of a circle on a sphere?
  • Context: Undergrad
  • Thread starter Thread starter jobyts
    Circle Circumference
The formula for calculating the circumference of a circle on a sphere is given by the equation 2πR sin(r/R), where r is the radius of the circle and R is the radius of the sphere. This formula accounts for the curvature of the sphere, distinguishing it from the standard circumference formula of 2πr applicable in flat geometry. When r equals πR, the circumference becomes zero, as sin(π) equals zero, indicating that the circle collapses at this radius. The discussion emphasizes the importance of understanding the relationship between the circle's radius and the sphere's radius in spherical geometry.
  • Spherical geometry concepts
  • Trigonometric functions, specifically sine
  • Understanding of radius and circumference in both 2D and 3D spaces
  • Basic knowledge of angles and their measurement in radians
  • Study spherical geometry and its applications in physics
  • Learn about the properties of trigonometric functions in different contexts
  • Explore the implications of curvature in higher-dimensional spaces
  • Investigate the relationship between radius and circumference in various geometric shapes
Mathematicians, physicists, and students studying geometry, particularly those interested in the properties of circles on curved surfaces.
jobyts
What's the circumference of a circle of radius r, on a sphere of radius R?
The circumference of a circle of radius r is 2\pi r, whether it is on a sphere or not.
The following i the context I was talking about:
From https://www.physicsforums.com/showthread.php?t=311787 post #6,
Imagine you fix one end of a string with the length r at a point in 2d-space, and make a full circle with the other end. If you then find that the circumference of that circle is different from 2*PI*r, you conclude that the 2d-space is curved intrinsically.
If r == PI*R, the circumference created by the string will be zero.
So you aren't talking about radius in the usual sense- you are having the "radius" bending around the sphere. And the "center" of the circle is also on the sphere, not inside it.
We can, without loss of generality, assume that the "center" of the circle is at the top of the circle, the "north pole". Draw a line from the north pole to the center of the sphere, then to a point on the circle. Let the angle made be \theta (\theta is the "co-latitude"). Dropping a perpendicular from the point on the circle to the line from north pole to center of sphere, we have a right triangle with angle \theta, hypotenuse of length R, and "opposite side" the (real!) radius of the circle, which I will call r' since we are using r for the "phony" radius. Then we have sin(\theta)= r'/R or r'= R sin(/theta).
Now, the circumference is "really" 2\pi r'= 2\pi R sin(\theta). We only need to calculate \theta in terms of r. The spherical "distance" is measured along a great circle and a whole great circle on a sphere of radius R has circumference 2\piR and corresponds to an angle of 2\pi. We can set up the proportion
\frac{2\pi}{2\pi R}= \frac{1}{R}= \frac{\theta}{r}
so \theta= r/R
That means our circumference formula becomes
2\pi r'= 2\pi R sin(\theta)= 2\pi R sin(r/R)[/itex]
<br /> <br /> If you input values such that r &gt; R, would you get an answer that is imaginary?
2\pi r&#039;= 2\pi R sin(\theta)= 2\pi R sin(r/R)[/itex]
<br /> <br /> Did I miss something?<br /> <br /> If r == PI*R, shouldn&#039;t the circumference created by the circle be zero?
It should, and it is, according to that formula. (\sin \pi = 0.)
  • · Replies 19 ·
  • · Replies 28 ·
