Co-Exist Dimensions - Exploring Possibilities
  • Thread starter scilover89
  • Tags
    Dimension
In summary, different dimensions coexist and it is possible that the same dimension exists separately in another dimension. Forces in a dimension will affect the other if they coexist.
scilover89
78
1.Is it possible that different dimensions co-exist?For example:3 dimension space and four dimension space
2.Is it possible that the same type of dimension exist separately in another dimension?(For example:Two 3-dimension space exist together in a higer dimension)
3.Will force in a dimension affect the other if multi-dimension co-exist? (For example:gravity)
Thank you.
1. In our ordinary 3 dimensional world we don't have a fixed separate 2-dimensional space; we can imagine a 2-dimensional plane in any orientation, for an infinite set of possibilities. Just so our 3 or 4-dimensional world can fit into a higher dimensional world in any of an infinite number of ways.
There are two cases in modern physics where dimensions are distinguished from another.
In relativity, time is a distinguished dimension from three dimensional space; the math reflects this by having the time and space coordinates have different signs in the metric.
In string physics the dimensions are distinguished by whether they are compacted or not. Three dimensions of space and one time dimension are uncompacted as we experience, and the other dimensions are compacted to tiny shapes.
2. Yes, if there were a higher dimensional euclidean space, as I said above, a three dimensional space could be "embedded" as they say in an infinite number of ways, and two such spaces could coexist, either parallel or intersecting.
3. This is a well known theory within string physics. Imagine that our spacetime is on the "surface" or boundary of a higher dimensional "brane" (or space). Physics would constrain the three quantum forces (electromagnetism, strong, and weak) to act only within our spacetime, but gravity could also propagate into the "bulk" as the higher space is called. Because gravity also spreads outside spacetime, only a fraction of its strength is available inside spacetime, and this is given as the explanation of why gravitation is so much weaker than the other forces.
"Because gravity also spreads outside spacetime, only a fraction of its strength is available inside spacetime, and this is given as the explanation of why gravitation is so much weaker than the other forces."
Dark matter and dark energy are primarily gravitational effects, at least as we can measure them. Would that suggest that they exist outside of spacetime.
Since dark energy is proportional the volume oif the universe, whereas dark matter is constant regardless of the volume of the universe, I would venture that Dark Energy spreads outside spacetime, but Dark Matter does not.
Any other thoughts?
Richard
Thanks for your reply, but what is dark energy? Is it energy of dark matter?
Anyway, if gravity force can effect other dimension, wouldn't that cause our dimension to crash with other dimension if another dimension exist?
If General Relativity is correct, then gravity creates space, or perhaps is identical to it. So if space is at least controlled by gravity, dimensions cannot come crashing in on other dimensions. In a sense gravity creates the dimensions.
the concepts of background independence suggest that the dimensional metrics and physics of a universe are emergent from a web of relationships- so I think there are likely parallel layers of structures that only interact with similar structures- so that what we call spacetime/matter is a lattice/matrix of structures which interact to form and define dimensional metrics/ causal relationships/ matter fields- but an infinitude of OTHER structures forming other such matrices/dimensional manifolds/ branes might overlap each other and never [rarely] interact because structures of these alien realms don't match-up/balance each other due to topology/ wave-frequency/ “dimension” or scale- so that "universes" would interpenetrate but never touch-
I like to imagine that our universe is made of the connections between legos- but there are lincoln log universes and tinker-toy universes overlapping ours- but since they can't connect with legos and the connections are all we are and can see- we don't see those other spaces- [but you never know- every so often a tinker toy stick might get lodged in a lego hole that just happened to be the right size and at the right "place"-]
A black hole maybe?
Perhaps traveling in the higher dimension is the only way to reach the other similar dimension(space)?
1. What is "Co-Exist Dimensions - Exploring Possibilities"?
Co-Exist Dimensions - Exploring Possibilities is a scientific concept that explores the possibility of multiple dimensions existing simultaneously within our universe. It suggests that there may be more than the three dimensions we are familiar with (length, width, and height) and that these dimensions may co-exist with each other, influencing the world around us in ways we may not yet fully understand.
2. How is this concept relevant to current scientific research?
This concept is relevant to current scientific research because it opens up new possibilities for understanding the fundamental laws of nature. It challenges our current understanding of the universe and encourages scientists to think outside the traditional three dimensions. By exploring the co-existence of dimensions, scientists can potentially uncover new insights and discoveries about the world we live in.
3. Is there any evidence to support the existence of co-existing dimensions?
While there is no concrete evidence to support the existence of co-existing dimensions, there are theories and mathematical models that suggest their possibility. Some scientists also point to phenomena such as dark matter and energy, which cannot be fully explained by our current understanding of the universe, as potential indications of the influence of other dimensions.
4. How does this concept impact our daily lives?
Co-Exist Dimensions - Exploring Possibilities has not yet directly impacted our daily lives, as it is still a concept that is being studied and researched. However, if proven true, it could potentially revolutionize our understanding of the world and lead to new technologies and advancements that we cannot currently imagine.
5. Are there any practical applications of this concept?
Currently, there are no practical applications of this concept. However, if proven true, it could have significant implications for fields such as physics, mathematics, and engineering. It could potentially lead to new technologies and advancements that could greatly benefit society and our understanding of the universe.
  • Beyond the Standard Models
