Coin Flipping Robot - Exact Paths & Results?
  • Thread starter Thread starter iDimension
    Robot
The discussion centers on the theoretical implications of a coin flipping robot operating in a vacuum, where all variables such as starting position and speed are controlled. Participants agree that if all external factors are eliminated, the coin would consistently follow the same trajectory and land on the same face. However, they note the practical challenges in creating a device that can achieve such precision, as no existing contraption has successfully removed enough variability to guarantee identical outcomes in repeated trials.
  • Understanding of classical mechanics and physics principles
  • Familiarity with experimental design and control of variables
  • Knowledge of vacuum technology and its applications
  • Basic concepts of probability and randomness in physical systems
  • Research vacuum chamber design and its impact on experimental outcomes
  • Explore the principles of deterministic systems in physics
  • Investigate existing experiments on controlled coin flipping and die rolling
  • Learn about precision engineering techniques for creating repeatable experiments
This discussion is beneficial for physicists, engineers, and hobbyists interested in experimental physics, robotics, and the study of deterministic versus stochastic processes.
iDimension
If you made a coin flipping machine that was contained inside a vacuum (or as close to a vacuum as you can get) and the robot flipped the same coin from the same starting position with the same speed etc, let the coin bounce on the floor and repeated the experiment with the exact same starting parameters, would the coin always bounce and following the exact same path and would it always land on the same face?
Is there any videos where we have created this type of device? I guess the same can be said for a die, if you throw it with the exact same force and starting position etc it would always bounce and roll in the exact same path.
Theoretically, yes. If you were to remove all variables from the system, you would expect the same outcome every time. I have never seen any contraption that was able to remove enough variability to get the same outcome every time.
  • · Replies 45 ·
  • · Replies 28 ·
