Coin tossing -extended version-
  • Level: Graduate
  • Thread starter Stellaferox
8 replies · 4K views · last reply
Stellaferox
Coin tossing ---extended version---
We learned in previous posts that to obtain a string of at least K Heads, one has to flip a coin 2^(K+1)-2 times (N) on average (Markov chains), e.g. K = 3 HEADS, N would be 14.
On the other hand: flipping a coin 14 times and calculating the probability that a string of at least 3 HEADS occurs, the probability = 0.647949219
The strange thing is that doing the string of HEADS from 1 to (let's say) 10 and calculating the matching average nr of flips (N = 2^(K+1)-2), reversing this exercise and calculating the probability of occurrence of such a string in N, is always around the above mentioned probability of 0.647949219.
Can someone please explain?
thnx in advance
Marc
These are not the same problem.
The first problem is getting the average of the number of flips to get a string of k heads. The second is the probability of a string of k length for a given string.
Let P(n,k) = prob(string of k after n flips|no string of k after n-1 flips)
The answer to the first is ∑(n=0,∞) nP(n,k)
The answer to the second is ∑(j=0,n)P(j,k)
Hi Mathman,
Thank you for your answer and the compact notation in logic of what it all boils down to.
Yes I know of course. What I wanted to know is how these compared probabilites all give a result closely around 0.64. I find it hard to believe that this is coin-cidental...(forgive the pun)
Marc
And, moreover, the probability seems to converge towards 0.6323 as K heads increases (with N = 2^(K+1)-2 as average number of coinflips to obtain a string of K heads)
Stellaferox is talking about a pattern that emerges when you calculate the probability of getting a run of k heads in a series of 2^(k+1)-2 tosses. It appears to tend toward some limiting value.
2 6 0.671875
3 14 0.647949
4 30 0.639057
5 62 0.635327
6 126 0.633651
7 254 0.632865
8 510 0.632487
The first column is k, the second is the number of tosses n, and the third is the probability of getting a run of k heads in n tosses.
This is neat. I had not noticed this before, and I don't know why it happens.
@ techmologist,
Yes, the question is really bugging me. How should we try to solve this equation? It is a bit hard doing this by numbercrunching as the bigger powers of 2 cannot be referenced anymore by excel or programming languages.
Marc
Stellaferox said:
@ techmologist,
Marc
Hi, Marc. I think I have guessed the answer (but not proved it). For large values of N and K, the number of runs of K heads in N tosses has a Poisson distribution with mean approximately N/2K+1. I got this approximate mean from considering the exact expected number of runs of K heads in N tosses, which is
[1+(N-K)/2]/2K
In the case we are considering, the mean number of runs of K heads approaches 1 as K grows large. Therefore, the probability that there is at least one run of K in N = 2K+1-2 tosses is 1 minus the probability that there are none:
P{at least one run of K heads in 2K+1-2 tosses} = 1 - P{0 runs of K heads in 2K+1-2 tosses} ~ 1-e-1 = 0.6321205588
Hi Techmologist,
I think you are right! I tried to substitute 2^(K+1)-2 for N in the probabilityformula and bring it to its limit but didn't succeed. your approach is much more elegant and intuitive I might say.
I didn't think of the Poisson-distribution either. Rather stupid considering I was playing with that function for the last month!
Thank you for your thinking along.
Marc
Stellaferox said:
Hi Techmologist,
Marc
You're welcome. I'm glad you brought this up because otherwise I wouldn't have thought to apply the Poisson approximation to the problem of runs. I still need to check it to see for what range of numbers it gives reliable answers.
I've thought about it some more, and it is possible to see the tendency toward 1-e-1 in the exact formula when you substitute in N = 2K+1-2. Actually, since we are letting K grow large (at a much slower rate than N), the probability doesn't change much if you simply use N = 2K+1. Also, we can ignore those series of N tosses that begin with a run of K heads, since their contribution to the probability is negligible as K increases. That way, we can focus on only those series in which a tail is followed immediately by a run of K heads. So if P is the probability of a run of K heads in N = 2K+1 tosses, then
[tex]P \approx \sum_{j=1}^{\lfoor\frac{N}{K+1}\rfloor}(-1)^{j+1}\binom{N-jK}{j}\frac{1}{2^{j(K+1)}}[/tex]
substituting N for 2K+1 gives
[tex]P \approx \sum_{j=1}^{\lfoor\frac{N}{K+1}\rfloor}(-1)^{j+1}\binom{N-jK}{j}\frac{1}{N^j}[/tex]
Since N/(K+1) --> infinity and (N-jK)j/Nj --> 1 as K grows large*, the above sum simplifies to
[tex]P \approx \sum_{j=1}^{\infty}(-1)^{j+1}\frac{1}{j!} = 1 - e^{-1}[/tex]
This reasoning can be extended to get the full Poisson distribution for the number of runs of K "successes" in a series of N Bernoulli trials, with success probability p and failure probability q = 1-p. If we let [tex]N = \mu/qp^K[/tex] as K grows large, so that N >> K >> 1, then for small j, the probability that there are exactly j runs of K successes in N trials tends to
[tex]e^{-\mu}\frac{\mu^j}{j!}[/tex]
*(n)i is shorthand for n(n-1)...(n-i+1)[/size]
