wofsy said:
so what? in my original example of the Stern-Gerlach experiment an eigen state of spin is isolated using a solution to the Shroedinger equation.
If a single silver atom passes through a Stern-Gerlach apparatus, its state (which I will write in the form |position,spin>) changes from |center,s> to a superposition of |right,+> and |left,->. This is not a measurement. It's just an interaction that produces a correlation between spin eigenstates and position eigenstates*, which enables you to determine the spin by measuring the position. A
measurement of the spin is an interaction which produces a correlation between the spin eigenstates and macroscopically distinguishable states of a system that for all practical purposes can be treated as classical.
*) They aren't really position eigenstates, but they are as close as you can get. They are superpositions of narrow ranges of position eigenstates.
For example, you can measure the spin state of a silver atom by letting it pass through a Stern-Gerlach apparatus and allowing it to be detected by one of two detectors that you have put in the two relevant positions. Each detector can always be described as
either having detected a particle or not having detected a particle.
So what the Stern-Gerlach apparatus does isn't a measurement. It's a state preparation. This concept is more clear if we consider an ensemble of systems instead of an individual system. If we send a beam of silver atoms into the apparatus, it gets split in two. The spin state of the initial beam is represented by the statistical operator (a.k.a. density operator, density matrix or mixed state) |+><+|+|-><-|. The state of the beam that comes out on the right is represented by the pure state |+><+|. What this means, at least for those of us who think of both state vectors and statistical operators as representing the probabilities of different measurement results (rather than as representing objective properties of physical systems) is that the "reduction of the state vector", "collapse of the wavefunction", or whatever you'd like to call it, isn't even an interaction that the system is involved in. It's a
selection of a subset of the ensemble, on which we indend to perform measurements.
Suppose that we only send one atom through, and that its initial state is |+>+|->. I like to think of a state vector as representing the probabilities of different results (and not as an objective property of the system), but this is equivalent to saying that the state vector represents an objective property of an ensemble of identically prepared systems. In other words, we have to imagine a large number of identical experiments being performed. The set of all silver atoms in all those experiments is an ensemble, and the "collapse of the wavefunction" is a selection of a subset of
that ensemble.
By the way, what I just described here is also described in the excellent book "Lectures on quantum theory: mathematical and structural foundations" by Chris Isham, which I read about a week ago. I had not understood the importance of distinguishing between state preparation and measurement until I read it.
