Collision with an object after circular motion.
8 replies · 3K views · last reply
dttah
"A bar line AB has a length of 1,5m and a mass of 0,5kg.
It is stuck in the point B in a horizontal fixed hub, and it can oscillate freely with no friction in the verical plane.
at time t=0, the bar line, which was still (not moving, inertia), is set free to rotate.
When it reaches the vertical position it hits a body of mass m2 = 0,2kg.
The bar line immediately stops, while the body m2 begins to move after the collision with a horizontal velocity.
Find: The angular velocity of the bar line, the linear velocity of its free extreme point (so A, i guess), and the velocity of m2 after the collision.
We have then:
AB = 1,5m
m1 = 0,5kg
m2 = 0,2kg
v0 = 0m/s
Alright, I didn't do too much actually, I am just starting out with these kind of problems.
I understand that as soon as the bar line is set free, it starts a circular motion, and the final velocity depends on the gravity acceleration ( I guess ). And that the impact will be at angle teta = pi/2.
Now, I don't really know where to start from.
I am thinking about finding the center of mass, is that the right path to begin with?
  • Diagram of a thin bar pivoted at its top-right end, hanging vertically down from a horizontal bar, with a small dark sphere at the pivot and a larger dark sphere at the lower end of the vertical bar.
We have then:
AB = 1,5m
m1 = 0,5kg
m2 = 0,2kg
v0 = 0m/s
Find the center of mass of the bar and determine how much its (gravitational) potential energy changes between the horizontal and vertical positions. This will tell you how much rotational KE it will gain. Use your knowledge of rotational mechanics to determine its angular velocity, etc.
Since there is no talking about density I can assume the center of mass is just L/2 so:
x = 0,75.
Right? Now I understand that I have to do something with energy, so like:
mgh = 1/2mv^2
But I have to decompose the motion in x and y. I am not sure if this is correct but this is my basic idea.
But I don't understand how may I find the angles in order to get the x and y components of the height.
  • Handwritten sketch of a circle with centre O and a point X on its left edge joined to O by a horizontal line, labelled X = centre of mass, OX = 0.75 m, with a blue chord drawn from X down to the bottom of the circle.
x = 0,75.
mgh = 1/2mv^2
That's good.
No, no decomposition is required. The change in gravitational PE for the center of mass of the rod goes into the rotational KE of the rod. There's only one rotational velocity, so no components required (a nice feature of rotational motion!) What's the formula for rotational KE?
It'd be 1/2Iw^2
where
I = momentum of inertia
So it'd be:
1/3ML^2 => 1/3 0,5kg * (0.75)
(I am not sure, but this should be it?)
Then I can do the following:
mgh = 1/2Iw^2
Where I have I, m and g.
I can assume that h = 0,75 because it'd be the radius, and so I could find the angular velocity?
dttah said:
It'd be 1/2Iw^2
where
So it'd be:
You have the correct formula for the moment of inertia of a thin rod about an end. But for some reason you've plugged in half the length of the given rod. That is not correct. You must use the full length of the rod, L = 1.5 m. The center of mass position doesn't enter into this formula. Otherwise, you've got the right idea!
mgh = 1/2Iw^2
Yes. h is the change in height of the center of mass of the rod (so you might consider calling it "Δh").
Ok so:
1/3ML^2 => 1/3 0,5kg * (1.50)
I = 0,25.
mgh = 1/2Iw^2
w = square root of... (2mgh)/I
So
w = 5,42 rad/sec
Velocity = radius * w => velocity = 1,50 * 5.42 = 8.13m/s
And then the other stuff is just an elastic collision which I should know how to handle.
Just one thing, in the velocity up here, I did right plugging in the radius "1,50" or it should've been 0.75?
Thanks a lot!
dttah said:
Ok so:
I = 0,25.
Oops. Looks like you forgot to square the length.
mgh = 1/2Iw^2
So
w = 5,42 rad/sec
The radius is correct; You want the distance from the center of rotation to the point of interest. If you sort out the small error in the moment of inertia calculation you should be good.
woops, my bad :)... okay got it! Thanks a lot. That's appreciated.
