SilverSoldier
- Messages
- 26
- Reaction score
- 3
- Homework Statement
- There are several concepts regarding these topics topic that I do not quite grasp well, that I have detailed below.
- Relevant Equations
- Impulse = Change in momentum (##I = \Delta mv##)
Law of Conservation of Momentum
Newton's Law of Restitution
Conservation of Energy
1. When an object attached to a fixed point with a string, is given a velocity and the string goes taut.
So it says in this book (Applied Mathematics 1 by L. Bostock and S. Chandler) that when the string goes taut, the component of the velocity of the particle becomes zero in the direction along the string.
The same book states that the final velocities along the direction of the string will be the same after an impulsive tension is experienced. Again, why must this be the case? What is wrong with the string not being taut? Can ##A## not move faster than ##B## after the impulse, and why?
3. When impulsive tensions act in the presence of other forces.
4. When two objects with external forces acting on them collide.
- Why must that be the case? Is it not possible that the particle acquires a velocity in the opposite direction, i.e., along ##BA##, according to the example given?
- If the velocity does for some reason become zero, what will happen immediately after the particle acquires this velocity? Is it only for as long as the impulse acts that there will be a tension in the string? Will there also be a tension after the impulse? How can it be calculated? Will the particle move in a circular path, and the tension be ##\dfrac{mv^2}{2l}##?
- In this example, don't the weights of the particles have any effect on the impulse that arises?
- Why do both particles acquire the same velocity due to the impulse?
- What happens after these particles acquire these velocities? Will there be a tension present in the string? Is it possible to calculate it? Will both particles accelerate as a system with the same accelerations, or will they accelerate differently?
- In a situation such as the following, where, say ##A## is thrown down with some velocity ##u## while ##B## is dropped from rest, and the string goes taut, what will happen? Can the above equations still be used? Does the presence an impulse and an external force along different directions, unlike in the pulley example above affect the problem in any way?
- If a particle ##P## that has a constant force acting on it, collides with another particle ##Q## moving at constant velocity, how will the particles move? Will they accelerate as a system?
- If ##P## is released from the top of an incline, and ##Q## is projected up along the incline at some velocity ##u##, what can we do to find out the velocities of the particles after the collision? If ##P## were instead thrown down the incline, it possible that after collision ##P## acquires a velocity greater than what ##Q## acquires, in the same direction? How will the particles move in such a situation?
