Combining translational and rotational velocities to get rotational velocity
The problem involves understanding the rotational and translational velocities of a forearm during specific movements. The context is centered around the angular velocities of the upper arm and elbow, and how these relate to the overall rotational velocity of the forearm in space.
  • Participants are exploring the implications of the problem's description, questioning how the rotational velocity is defined and measured. There is uncertainty about the reference points needed for calculating angular velocities and how to combine different types of velocities.
The discussion is ongoing, with participants expressing confusion about the relationship between the rotational velocity of the shoulder and the translational velocity of the elbow. Some guidance has been offered regarding the interpretation of rotational velocity as angular velocity relative to the surrounding space, but clarity on combining these velocities remains elusive.
Participants note potential missing information regarding the reference points for measuring rotational velocities, which may affect their understanding of the problem. There is also a reference to a related scenario involving a rotating amusement park ride to illustrate the concepts being discussed.
aplysia
Suppose you are standing uptight with your right arm stretched out straight in front of you, palm down, the upper arm rotating rightward relative to space at 2 radians/s and the elbow flexing in the horizontal plane at 2 radians/s. What is the rotational velocity of the forearm in space?
I am not sure if I understood the description of the movement correctly, because now I have the impression that there are informations missing I would need to solve this, e.g, on which point on the forearm the rotational velocity is measured, because I thuoght that would depent on the point on the forearm.
Maybe this is the situation?
Thanks, that might indeed be the situation, my main problem is really that I am not sure if I understand the descprition of the problem.
What also confuses me is what rotation of forearm relative to space means in this context the velocity of on specific point on the forearm or if it refers to the angular velocity of the forarm.
I know that angular velocity is given by v=w*r, but I alway thought I needed some kind of reference point r to calculate angular velocities.
Also I am unsure of how to combine rotational and translational velocities
any hint to find the right approach is greatly appreciated,
aplysia
I think you just want angular velocity. So, no need to pick a specific point on the arm or worry about v. Rotational velocity relative to space is the same as angular velocity relative to the room the person stands in.
Then I really do not understand how the rotational velocity of the shoulder and the translational velocity of the elbow are related to each other and how they result in the rotatinal velocity, maybe I miss something really obvious here, but right now, I can't see how they result in the rotational velocity
Hope my interpretation of the problem is correct.
Remember when you rode the Spinning Teacup amusement park ride? (One of my favorites.) See attachment.
Suppose that the green platform that the cups are riding on is rotating clockwise at 2 rad/s and suppose one of the teacups is rotating counterclockwise at 2 rad/s relative to the green platform. At what rate would the teacup rotate relative to the ground?
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 26 ·
23K
