Commutator of function of operators
The discussion centers on the validity of the commutator relations [f(A), B] = [A, B] df(A)/dA and [A, f(B)] = [A, B] df(B)/dB for operators A and B. While specific cases can be proven, the general formula requires the assumption that the commutator [A, [A, B]] = [B, [A, B]] = 0 holds true. This condition ensures that the derived expressions simplify correctly, particularly when using power series expansions. The relation e^A e^B = e^{A+B+[A,B]/2} is identified as a special case of the Baker-Campbell-Hausdorff formula, applicable when the commutator commutes with both A and B. The conversation concludes with a suggestion to explore the extension of these formulas to product functions and other forms.
kini.Amith
According to my teacher, for any two operators A and B, the commutators
[f(A),B]=[A,B]df(A)/dA
and [A,f(B)]=[A,B]df(B)/dB
He did not give any proof.
I can easily prove this for the particular cases
[f(x),p]=[x,p]df(x)/dx
and [x,pn]=[x,p]npn-1
But I don't see how the general formula is true. I also can't find it in any textbooks.
Likes curious_mind
kini.Amith said:
According to my teacher, for any two operators A and B, the commutators [f(A),B]=[A,B]df(A)/dA
I am not sure that's true.
Expand f(A) in terms of a power series. Take the derivative of that to give df(A)/dA and then check if equal. I can't see how it is without further assumptions.
Thanks
Bill
But he used this formula to prove eAeB=eA+B+[A,B]/2.
To be exact, he took [eAt,B]=[A,B]teAt in one step of the proof.
Expand them out and have a look at the first term - are they equal?
To be exact the first term on LHS doesn't have t in front - yet the first term on the RHS does.
Added Later:
Wait a minute - the first term contains I which always commutes so is zero. That might be the assumption he is making - if the first term of f(A) commutes with B it may hold. I will check at get back.
Yea - the assumption he is making is the power series expansion is in terms of scalars ie f(A) = a0 + a1A + a2A^2 ... and a0, a1 etc are scalars.
I think if you insert and equate then the formula are true.
Thanks
Bill
This is only true if
[A,[A,B]] = [B,[A,B]] = 0.
That is, the commutator of A and B must commute with A and B for the formula to be true. In the case of x and p, their commutator is a scalar and it therefore holds. However, there is no guarantee for arbitrary A and B. The relation
e^A e^B = e^{A+B + [A,B]/2}
is a special case of the Baker-Campbell-Hausdorff formula (see http://en.wikipedia.org/wiki/Baker–Campbell–Hausdorff_formula) for when ##[A,B]## commutes with ##A## and ##B##.
Just to expand a bit on the series expansion.
Expanding ##f(a)## gives
f(a) = \sum_{n=0}^\infty \frac{d^n f}{da^n} \frac{a^n}{n!} \equiv
\sum_{n=0}^\infty k_n a^n
and thus
\frac{df(a)}{da} = \sum_{n=0}^\infty k_n n a^{n-1} = \sum_{n=1}^\infty n k_n a^{n-1}.
Now, in the same way
f(A) = \sum_{n=0}^\infty k_n A^n,
which implies
[f(A),B] = \sum_{n=0}^\infty k_n [A^n, B].
We can here make use of the commutator relation
[A^n, B] = \sum_{k = 1}^n A^{n-k} [A,B] A^{k-1}
to rewrite this as
[f(A),B] = \sum_{n=0}^\infty k_n \sum_{k = 1}^n A^{n-k} [A,B] A^{k-1}.
Now, if ##[A,[A,B]] = 0##, then
A^{n-k} [A,B] A^{k-1} = [A,B] A^{n-1}
and
\sum_{k = 1}^n A^{n-k} [A,B] A^{k-1} = [A,B] A^{n-1} \sum_{k=1} ^n 1 = n [A,B] A^{n-1}.
The expression would then simplify to
[f(A),B] = [A,B] \sum_{n=0}^\infty k_n n A^{n-1} = [A,B] f'(A).
The last expression is of course also equal to ##f'(A) [A,B]##, since ##[A,B]## commutes with ##A##.
Likes curious_mind and kini.Amith
Thanks a ton.
kini.Amith said:
Thanks a ton.
Yea - me too.
It had me scratching my head a bit as well.
Thanks
Bill
Heh, now show that the formula extends to product functions, and to functions of the form 1/f(x). :-p
  • · Replies 17 ·
