Commutator of ##L^2## with ##L_x,L_y,L_z##...
  • Context: Undergrad
  • Thread starter Thread starter Apashanka
    Commutator
The discussion centers on the relationship between the eigenstates of the angular momentum operators ##L^2##, ##L_x##, and ##L_z##. It is established that while eigenstates of ##L_x## are also eigenstates of ##L^2##, the converse is not true. The participants clarify that degeneracy in eigenstates does not guarantee simultaneous eigenstates across different operators. Furthermore, they emphasize that linear combinations of degenerate eigenstates can yield common eigenstates for both ##L_x## and ##L^2##.
  • Understanding of quantum mechanics and angular momentum operators
  • Familiarity with the concepts of eigenstates and eigenvalues
  • Knowledge of irreducible unitary representations in quantum mechanics
  • Basic grasp of commutation relations among operators
  • Study the properties of angular momentum in quantum mechanics, focusing on ##L^2## and its eigenstates
  • Learn about the implications of degeneracy in quantum systems and how it affects eigenstates
  • Explore linear combinations of eigenstates and their role in forming common eigenstates for multiple operators
  • Investigate the structure of irreducible representations of the rotation group in quantum mechanics
Quantum physicists, graduate students in physics, and anyone studying angular momentum in quantum mechanics will benefit from this discussion.
Apashanka
TL;DR
##[L^2,L_i]=0##.....where ##i=x,y,z##
For a given state say ##{l,m_l}## where ##l## is the orbital angular momentum quantum no. and ##m_l## be it's ##z## component...a given state ##|l,m_l> ## is an eigenstate of ##L^2## but not an eigenstate of ##L_x##...therefore all eigenstates of ##L_x## are eigenstates of ##L^2## but the reverse is not true... isn't it??
Correct. When you have a degeneracy, an eigenstate corresponding to the degenerate eigenvalue is not necessarily an eigenstate of another operator that commutes. However, it is always possible to find a linear combination of these degenerate eigenstates that will be eigenstates of both operators.
@DrClaude : Sorry -- I must be missing something...
If we are given only that ##L_x \Psi = m \Psi##, how does that imply ##\Psi## is necessarily an eigenstate if ##L^2## ?
Maybe I'm overlooking a tacit assumption?
OP uses ##m_l## to mean as common eigenstate of Lz, usually z is taken, and L^2.
Otherwise, eigenstates of m in general includes states of l=0,1,2,3,... and eigenstates of l in general includes the states of m=−l,−l+1,0,1,2,3,...,l
One can play a role of sub-index of the other.
For an example, s electron and p_z electron are both eigenstates of m=0. We can distinguish them by value of l as sub-index because of the commutation of L^2 and Lz.
For a given ##l## the eigenstates of ##L_x## are some linear combinations of ##|l,m_l>## which are also the eigenstates of ##L^2##...
OP was looking at states that are eigenstates of ##L^2##.
Of course, this works both ways. eigenstates of ##L_x## are not necessarily eigenstates of ##L^2##, but there exists a linear combinations of the degenerate ##L_x## states that form a common basis for ##L_x## and ##L^2##.
Starting from ##L_+ = L_x +iL_y## and ##L_- = L_x - iL_y##, we get:
$$L^2 = L_x^2 + L_y^2 + L_z^2 = L_+L_- -\hbar L_z + L_z^2$$
And any eigenstate of ##L_z## is an eigenstate of ##L^2##. And, by symmetry, the same is true for ##L_x## and ##L_y##.
No! There are eigenstates of ##L_z## that are not eigenstates of ##L^2##, e.g., ##|l_1,m \rangle+|l_2,m \rangle## with ##l_1 \neq l_2##.
Yes, of course. I didn't think of that.
PeroK said:
And any eigenstate of LzLzL_z is an eigenstate of L2L2L^2. And, by symmetry, the same is true for LxLxL_x and LyLyL_y.
More precise saying is
we can find common set of eigenvectors for the two operators, i.e.,
L^2|l,m>=l^2|l,m>
L_z|l,m>=m|l,m>
May I remind that
\sum_m c_m|l,m> is an eigenvector of L^2 with eigenvalue l^2, but not an eigenvector of L_z anymore ?
strangerep said:
how does that imply \Psi is necessarily an eigenstate of L^2 ?
L^2 is a central element (Casimir) of the universal enveloping algebra, hence in an irreducible unitary representation, it has every vector as eigenvector.
In a specific unirep, yes, but not in general, as Hendrik pointed out in his post #8.
In every irreducible unitary representation. The rep specified in post #1 is of this form, while that in #8 is not.
We were talking about all eigenvectors of ##L^2## and ##L_z##, and there an eigenvector of ##L_z## is not necessarily also an eigenvector of ##L^2##.
Of course if you restrict yourself to a subspace, which builds an irreducible representation of the rotation group, than it's an eigenspace of ##L^2## to only one eigenvalue ##\hbar^2 l(l+1)## and thus in this subspace all vectors are eigenvectors of ##L^2## with this eigenvalue.
Yes, of course. But I was trying to clarify Dr Claude's post#2, which omits some of the OP's context. (Anyway, I think this thread has run its course, and then some. <Exit>)
  • · Replies 18 ·
