Compact highly directional medium wave antenna designs?
23 replies · 16K views · last reply
Flyboy
I know that there are highly directional shortwave/HF and VHF antenna designs that can be made fairly compact, but is it possible to do the same for medium wave, i.e. below 3MHz? I can’t seem to find anything helpful online about any theory that would point to a shape, let alone an actual example.
Is this due to the wavelengths involved?
RX only. The intent is to use it for direction finding using 1940s technology.
How compact and how accurate? I found some new DF instruments that can operate down that low in frequency, but they are still 10 meters or so in terms of antenna separation, and use pretty sophisticated new technology:
https://www.morcom.com/direction-finding-systems
WD-6300 HF Direction Finding System[/size][/size]
This system is designed to provide precise direction finding (DF) for HF signals. It has a frequency range of 500KHz to 40 MHz. It employs a sophisticated phase-coherent multi-channel interferometer-based method, combined with statistical signal processing. This delivers a cost-effective, robust, and precise HF DF solution. This system is designed for the for government, military, and law enforcement applications that require geo-locate HF emitters.
The system is small, lightweight, ruggedized, making it suitable for deployment in stationary and portable situations. Each WD-6300 system consists of three core parts: antenna array, three phase-coherent receiver channels, and associated processing computer.
The WD-6300 is a true none-commutated system that provides excellent performance against short duration signals. The sensing antennas utilized are specially adapted AX-81SM active monopoles. The antenna array size can simply be adjusted to match the system's desired frequency range. The antennas are positioned in a “L”-shape configuration, with each leg typically 5 meters in length for optimum coverage from 3 MHz to 30 MHz, and typically 10 meters for best coverage between 1 MHz to 15 MHz.
In addition to precise azimuth measurements, the WD- 6300 system can also measure an incoming signal's elevation. Providing the height of the reflecting ionospheric layer allows for an estimation of the target’s location without resorting to a standard multi-sensor approach for the necessary triangulation.
The entire antenna array can be assembled in less than thirty minutes by two people, while the receivers and the processing computer system can be operated either stationary or installed inside a suitable vehicle.
There are many possible solutions. The biggest problem is that HF signals wander ±2° in azimuth and ±30° in elevation due to ionospheric changes. You will need to trade gain for directivity, because HF DF accuracy comes from the narrow deep null, not the insensitive main lobe. Almost all HF DF techniques were operating during WW2. Many during WW1. Only interferometry using fields of small loops have emerged more recently.
A single, rotatable, tuned loop, will have a deep null.
Two rotatable loop antennas, mounted together with 5° between their axes, switch between them at 1 kHz, detect the 1 kHz in the received signal, and null that. The inverse system was the Lorenz beam landing system and Knickebein.
https://en.wikipedia.org/wiki/Battle_of_the_Beams
https://en.wikipedia.org/wiki/Battle_of_the_Beams#Knickebein
Two travelling wave wires, in a fan towards the target. Install series capacitors in the antenna wire, to give super-luminal velocity factor over the ground plane. That can have such a fine beam that you cannot find the target, back off a bit on the vf.
Crossed Bellini-Tosi loops, a two channel receiver, with one LO, feeding the x-y plates of an oscilloscope. Often used for broadband lightning direction detection.
https://en.wikipedia.org/wiki/Bellini–Tosi_direction_finder
HFDF, Huff-Duff, used to find submarines in the Atlantic.
https://en.wikipedia.org/wiki/High-frequency_direction_finding
https://en.wikipedia.org/wiki/High-frequency_direction_finding#Description
Something that you could fit two of to a fighter-sized airframe with 1940s technology. I know they could do that easily enough with the electronics, but they required a navigator to make sense of the data.
Accuracy… as long as it’s relatively close, i.e. able to use two to triangulate within a mile or two is fine.
Elevation is a non-issue, but azimuth accuracy is important.
Basic premise is trying to come up with a plausible passive terminal guidance system for an early nuclear-tipped cruise missile for an alternate timeline. The concept is to use two direction finders to get a read on two separate commercial radio stations to figure out the target point after cruising on autopilot to get close. This is only supposed to be an interim measure, as widespread rollout of the VOR navigation network is still a few years down the road.
Basic concept schematic:
Handwritten sketch of a bombing run: a missile flies south at 17,500 ft, detects Station A at 130 magnetic, descends to 2000 ft AGL, detects Station B at 90 degrees right of Station A, then detonates at the target. Station A 1470 kHz, Station B 950 kHz.
"Close only counts in horseshoes, hand grenades, and, well, ..."
Flyboy said:
nuclear-tipped cruise missiles
Correct. 😆
It’s not meant to be a pinpoint system, but enough to make sure you’re in the right area. A purely internal system like inertial navigation would not be practical at the time, and the computing power to do triangulation along the flight path to correct for navigation errors would be prohibitively expensive and bulky to use on a throwaway system. I figured that using the angle between two known, fixed emitters in the target area would be a fairly viable option.
Downsides are that if your enemy catches wind of your guidance concept, they will shut down the radio stations if they know an attack is imminent, denying you the ability to guide off of them, and the fact that you basically get one shot per city. After all, the nuke is likely to disable or destroy the radio towers in the area.
So it sounds like this is for a SciFi story or similar? It's probably a specialized enough question that we can keep this thread in the EE forum for now. :smile:
Alternate timeline story, but yes.
The technical aspects are exactly why I placed it here instead of in the Scifi world building forum.
That will map to a hyperbola, not a point on the ground.
Two points need a reference direction. Is your reference from an inertial system or a gyrocompass that was spun up before launch ?
No compass is needed with a three point resection, only two of the angles between the three points need to be measured.
https://en.wikipedia.org/wiki/Position_resection_and_intersection
MW transmitters transmit horizontally, towards the horizon, there is no signal directly above, so the system may be blind.
V or H polarisation of the received MF wave, will require a crossed dipole antenna for the receiver, maybe setup for circular polarisation, so orientation is unimportant and only one receiver is needed.
I’m not sure I understand. If I know that the bearing from the target to one station is, as in the example diagram, 130° magnetic, and the second one is at 210°, that produces an angular difference of 80°, correct? If you know which one is which based on the frequency and know you’re coming in from one side of the target, wouldn’t that leave only one possible point where the bearings match up? I’m operating on the assumption (and I’m fully aware of the danger that represents 😆) that I can use the axis of the aircraft’s travel as a third angle. So, I can tel that Station A is ahead of me, and Station B is on my right, and I can measure the difference between the two DF seekers to tell when it’s the right place.
I was thinking of using a fluxgate compass paired with a gyrocompass. It’s available at the time, if a bit new, but it simplifies gathering direction data. A manually input magnetic declination adjustment would be part of setting up the missile prior to launch.
I’m trying to make it as simple and compact as practical. A bit brute force, as it is intended to be used by the Soviets.
I don’t expect to be using direct overflight of a station as a navigation tool, but it certainly could be useful in later designs to provide a known point for INS realignment.
As for polarization… whatever gives the best angular resolution for US AM radio broadcasts.
That only works if you are certain of your flight path before launch.
Immediately there is a nuclear attack, MW transmitters will go off the air. Your MW navigation will only work for the first missile in the area. It is becoming more like a cruise missile than a re-entry vehicle.
Magnetics are avoided in nuclear missiles due to EMP above the target area, the nuclear umbrella.
Soviet military electronics used vacuum tubes into the 1970s, since they can arc-over and recover, unlike semiconductors.
A gyrocompass is only of use at a mobile launch site, when you need to know a reference direction. A gyrocompass will not help navigate over the pole, because it is vertical. An inertial set of two or three gyros would be needed to cross the pole.
One gyro was stabilised before launch in WW2 torpedoes, but that was over a short range, and assumed a flat-Earth.
Check out the navigation of WW2 V2 rockets. They used integrating gyros to determine range, as did Cold War missiles on both sides.
I suppose I didn’t do a good job explaining the intent. It is a cruise missile, albeit an early one, intended to provide bombers with a degree of standoff. It’s meant to be a first-strike weapon, not a launch-on-alert weapon. It is also an interim solution while they work out more capable inertial nav systems and while they figure out how to get acceptable accuracy out of ICBMs.
The loss of radio towers is something that I did recognize as a weakness in a previous post, alongside the countermeasure of simply turning off the radio towers to deny targeting.
The target timeframe is intended to be starting development in the immediate aftermath of WWII and the rapid developments that spun out of that, and is supposed to be a brute force, quick solution to buy time for more elegant/efficient solutions.
The V-1 rockets had reasonable accuracy by the end of WWII -- adding the nuclear warhead capability seems like it would be enough for your scenario, no?
https://en.wikipedia.org/wiki/V-1_flying_bomb
Initially, V-1s landed within a circle 31 km (19 mi) in diameter, but by the end of the war, accuracy had been improved to about 11 km (7 mi), which was comparable to the V-2 rocket.[35]
EDIT -- Although, I guess all they had were fission bombs at that time, which only have a blast radius of a mile or so. So maybe the increased accuracy would be needed. Can you have a mole/spy/special forces operative set up hidden transmitters in the target cities ahead of time? If so, you could use VHF/UHF transmitters to make the DF setups smaller on your cruise missiles.
Yep, the (relatively) small blast radius and low yield are definitely driving factors in needing better guidance.
The issue with getting beacons in place is that it’s time and personnel intensive, runs the risk of getting caught, and will probably be shorter range than using the commercial radio stations that are already present around the majority of cities that would be probable targets. Determining their coordinates and frequencies is fairly easy and doesn’t attract much, if any, attention. They’re looking for quick and simple.
Okay, since we're moving out of strict EE antenna issues and more into the world building aspect of your story, I'll go ahead and move this thread to the SciFi World Building forum to get you additional views. :smile:
… might be a fun read regardless. 😆
Adding to the shopping list.
As a nuclear cruise missile, there would be no need for a V1 to dive. An air burst at a height of 3000 feet would maximise the damage.
The V1 was also air-launched as a missile, and could carry a one tonne payload. There were plenty of skilled technicians available at the end of WW2, who could have given the V1 a crude guidance system. But it is more likely that a human guided V1 would have been used to deliver a nuclear warhead.
Hanna Reitsch test flew the air-dropped, piloted version of the V1, designed as a human-guided bomb for suicide attacks.
https://en.wikipedia.org/wiki/Fieseler_Fi_103R_Reichenberg
Airburst was definitely the plan. But I don’t know how willing anyone would be to pull a full-on Major Kong and ride one of these in. Even KGB would probably hesitate.
I don’t think they would use a V-1 or derivative thereof, either. They didn’t get their first nuclear bomb until August 1949, and that one tipped the scales at over 4 tons. It would need to be a dedicated design to carry something that big…
Hmmm. Might have to wait a few years, to 1953 or so, when they get a relatively lightweight weapon.
Please elaborate/explain. I don't recall this from my brief training in design for EMP in the 80's for DOD satellites. Basically, the short version that I recall is that semiconductor junctions all conduct when hit with gamma ray transient events. Avoiding damage (like shoot through in a bridge) and recovering from transients is key. Granted, nearly everything will be upset (like magnetic data storage?), but I would imagine magnetic structures would be pretty hard to break.
BTW, I'm not trying to be obnoxious, there's actual curiosity involved here. Links, maybe?
The early Soviet Union nuclear defence was the nuclear umbrella, that was high-altitude nuclear explosions over Soviet Union cities. The magnetics I was referring to, was the use of a fluxgate compass, or declination, proposed by Flyboy to navigate to target. Ionospheric currents within the umbrella would disrupt the Earth's field near the city.
Vacuum tube technology in Soviet Union military avionics. There are many google hits, a quick example ...
https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-25#Western_intelligence_and_the_MiG-25
1964–1984"The majority of the on-board avionics were based on vacuum-tube technology, more specifically nuvistors, not solid-state electronics. Although they represented aging technology, vacuum tubes were more tolerant of temperature extremes, thereby removing the need for environmental controls in the avionics bays. With the use of vacuum tubes, the MiG-25P's original Smerch-A (Tornado, NATO reporting name "Foxfire") radar had enormous power, about 600 kilowatts. As with most Soviet aircraft, the MiG-25 was designed to be as robust as possible. The use of vacuum tubes also made the aircraft's systems resistant to an electromagnetic pulse, for example, after a nuclear blast. They were also presumably used to provide radiation hardening for the avionics.[37][38]"
Yes, design for EMP is a real thing. Hopefully, key DOD systems have been designed accordingly. I know first hand that the Pentagon cared a lot about this 40 years ago. You don't have to use vacuum tubes, but you can't do "normal" commercial designs. Your router and TV will be toast. OTOH, so will you.
BTW, remember this the next time you read about how expensive a new fighter jet is.
