What Happens to 1D Dimensions When They Curl Up in Superstring Theory?
  • Context: High School
  • Thread starter Thread starter bluecap
    1d 2d
The discussion centers on the implications of compactifying one-dimensional (1D) lines in superstring theory, specifically how they relate to higher dimensions. Participants clarify that curling a 1D line does not inherently transform it into a two-dimensional (2D) object; rather, it becomes an embedding in a higher-dimensional space. Key points include that wavelengths smaller than 1 mm behave in three-dimensional space, while larger wavelengths exhibit two-dimensional characteristics. The conversation also touches on the nature of extra dimensions, particularly within Calabi-Yau manifolds, and the challenges of visualizing these concepts in relation to our macroscopic world.
  • Understanding of superstring theory and its dimensions
  • Familiarity with Calabi-Yau manifolds
  • Knowledge of wave-particle duality and wavelength behavior
  • Basic grasp of dimensional embedding concepts
  • Research the properties of Calabi-Yau manifolds in string theory
  • Explore the implications of compactified dimensions on particle physics
  • Study the relationship between wavelength and dimensional behavior in quantum mechanics
  • Investigate the role of bosons in higher-dimensional theories
The discussion is beneficial for theoretical physicists, cosmologists, and students of advanced physics who are interested in the complexities of string theory and the nature of dimensions beyond our observable universe.
bluecap
When you curl 1 dimensional thing like a line.. won't it become 2D?
I'm trying to imagine how a compactified dimension in superstring theory actually look like in our world.
Let's take our 3D world and say the depth got compactifed or curl up to Planck length or a millimeter. What kind of bosons can you produce that can navigate the 1 millimeter curl up dimension? Would it also travel at speed of light?
Mathematics news on Phys.org
For large length scales it will become 0 D (it looks like a single point), for small length scales it stays 1D (you can only move forward and backward).
If you curl up a line in our three-dimensional world you will use the second dimension, but this is an embedding of the line in some other space - it is not a property of the line (curled or not) itself.
In general, everything with wavelength much smaller than 1 mm will behave as in a regular 3-dimensional space, everything with a wavelength much larger will behave as in a 2D space, and everything in between is more complicated.
But if you curl the line, won't it become circular in small length scale so you don't just move forward and backward but in circle too?
can the moduli field inside calabi-yau manifold able to affect us? Is there a mediator field where you can couple the moduli field with our large scale field like EM?
Can you move forward and backward (and sideward) on the surface of Earth?
Same concept. Sure, if you go 40,000 km in one direction you'll end up where you started, but that is very long compared to a typical walk.
I don't understand that question.
But the point is.. if you bend any 1D line.. it becomes 2D.. you may say at large length scale it becomes 0D.. while at small length scale.. it is same 1D.. but it's not the same.. because the line becomes curve (when you curl (or compactify it) so it becomes 2D. Gets?
Anyway. Any graphics to illustrate what it's like to compactify the dimension of depth in the 3D.
No it does not, that is the point. This is a statement about the geometry of the line, not of an embedding of the line in some higher-dimensional space. These are different things.
Ok. Got it. Anyway when a macroscopic dimension has size of say 1 light year.. how can you curl it into Planck size? how many turns of curling would there be?
Remember in 10D string theory 6 of the macroscopic dimensions curled up into Planck size.. so how many turns of packing it in or near Planck scale can you fit an infinite size dimension?
This is not a process. A dimension is either curled up or not.
Multiple turns are not a meaningful concept. See the surface of Earth as analog again: You can only go around the equator once before you reach your origin again. If you continue walking in the same direction, you just go along the same path again.
Let's say you curled up one of the 3D dimensions in your living room to 1mm.. so there is no more vertical above 1mm and everything is 2D on the floor (seen from large length scale).. would your table or bed still occur inside the 1mm?
See above: It is not a process. You either have a living room with a curled up dimension or you do not.
There is no "above 1mm" if the height dimension is curled up.
This question is meaningless.
mfb said:
See above: It is not a process. You either have a living room with a curled up dimension or you do not.There is no "above 1mm" if the height dimension is curled up.This question is meaningless.
I mean if you initiate the curling up in an already existing large dimension. Maybe your table or bed would just implode or would it somehow end up in the 1mm curled up dimension (from large infinite extend) intact? Just want idea and versatibility of the concept.
I have no idea how to make it clearer than that, sorry. If you don't understand "it is not a process" I cannot help here.
I see. So you mean when the Big Bang happened.. the 6 (or whatever) dimensions were already started as compactified?
I'll read the book now called "The Shape of Inner Space: String Theory and the Geometry of the Universe's Hidden Dimensions"
https://www.amazon.com/dp/0465028373/?tag=pfamazon01-20
Thanks for your assistance. It can make me visualize (or conceptualize) compactified dimensions better.
mft, I got your point.. that the curl up dimension was created right at the Big Bang (supposed these exist). No problem about that. Now supposed there were Calabi-yau manifolds with 6 curled up dimensions. Is the 6 curled dimension in my room directly connected to your room? If so, how do you send a boson that can only travel in the curled up dimensions and doesn't use the existing larger dimension? This is just to visualize the whole idea. Thank you.
"connected" doesn't make sense. If there are extra dimensions, your room has them, and every "place" in the room is actually a small 6D space in the 9D space. The spatial dimensions are so small that most particles are indifferent to them - their wave function is the same at all places along these extra dimensions.
You don't. With sufficient energy a boson can differ along these small dimensions, and then motion along these dimensions becomes possible.
If there are extra dimensions, the Earth has them, and every "place" on Earth is actually a small 6D space in the 9D space. Therefore my room is connected to yours via the 6D space.. so why do you say "connected" doesn't make sense?
Ah. You mean Planck energy bosons. It is said you need cosmic size particle accelerator to inject the photon into the compactified dimension.. no problem about that. But what do you mean a boson can differ along these small dimensions, and then motion along these dimensions becomes possible, any example or reference?
If there are compactified dimensions. It is implausible that they should rely on Planck size bosons to communicate. It's like Earth relying on the energy of pulsars to communicate in the surface. Maybe there are native scalar particles inside the compactified dimensions that are non-herztian, non-vectorian and has other mode of propagation?
Are our rooms "connected via height" as well? What does that even mean?
No I do not.
The extra dimensions, if they exist at all, could be large enough to be found by the LHC with more data. Likely? Depends on who you ask. Possible? For sure.
You seem to have some strange imagination of how compact extra dimensions would look like.
Let's try an analogy: 2 large space dimensions (x,y) and one small one (z). Let's make it 5 meters wide. You can freely move in all directions, space is three-dimensional for you. If you move in x and y direction you can explore other regions of space. If you move in z direction, after just 5 meters you return to where you started. If you move in a 45 degree angle to x and z, after 5*sqrt(2) meters you end up at the same z coordinate but now 5 meters shifted in x. You can explore space that way as well, you are just a bit slower. This is how the world looks like for particles at high energy - with a wavelength shorter than the length of the compact coordinate.
Now let's make the extra dimension smaller - 0.4 m. If you try to orient yourself along the z direction you'll hit yourself, you have to "lie" in the x/y plane. How does a house get designed in this world? The room layout will simply be an x/y-map. The z direction is too small to make walls or anything similar there. For someone designing this the world looks 2-dimensional. This is how the world looks for particles at low energy - with a wavelength longer than the length of the compact coordinate. For an ant, it still looks three-dimensional, because it is so much smaller.
mfb said:
Are our rooms "connected via height" as well? What does that even mean?No I do not.
This is great description! Brian Green depicted space as having many Cabali-Yau manifolds in his book Elegant Universe like the following I saw at google
It confused me for over 15 years...
So the universe has only one say 6-dimensional Calabi-Yau manifold?
But then since the dimensions are very small.. is it possible that in our solar system and andromeda, there could be different Cabali-Yau shapes? Or if you can alter the flux and moduli, can you change the shape of the Cabali-Yau at will at a small test locality?
The image can be misleading.
If it has that at all.
I'm not aware of any model that would predict this.
  • · Replies 0 ·
