MHB Complementary & Supplementary Angles
  • Thread starter Thread starter bernardl
    Angles
The discussion focuses on solving problems involving complementary and supplementary angles. For the first problem, it is established that the measures of angles P and Q sum to 180 degrees, with P being defined as three less than twice Q. The second problem involves angles B and C, which sum to 90 degrees, with B being two more than three times C. The participants emphasize the importance of showing work to facilitate better assistance. The solutions involve setting up equations based on the definitions of supplementary and complementary angles.
bernardl
The m<P is three less than twice the measure of <Q. If <P and <Q are supplementary angles, find the measures of both angles.
The m<B is two more than three times the measure of <C. If <B and <C are complementary angles, find the measures of both angles.
Mathematics news on Phys.org
Hello! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
I honestly don't know how to do both of those questions!
O.k., let's try the first one. mP + mQ = 180 degrees. mP = 2mQ - 3. Make sense? Can you solve it now?
"The m<P is three less than twice the measure of <Q. If <P and <Q are supplementary angles, find the measures of both angles."
Do you know that "supplementary angles" means their measures sum to 180 degrees? m<P+ m<Q= 180. You are also told that m<P= 2m<Q- 3 so (2m<Q- 3)+ m<Q= 3m<Q- 3= 180. Solve that for m<Q then use m<P+ m<Q= 180 to find m<P "The m<B is two more than three times the measure of <C. If <B and <C are complementary angles, find the measures of both angles."
"Complementary angles" are angles whose measures add to 90 degrees. So m<B+ m<C= 90.
"m<B is two more than three times the measure of <C" means that m<B= 3m<C+ 2.
So m<B+ m<C= (3m<C+ 2)+ m<C= 4m<C+ 2= 90. Solve that for m<C then use m<B+ m<C= 90 to find m<B.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
