Completely expand as a sum/difference of logs
  • Thread starter Thread starter lolilovepie
The problem involves expanding a logarithmic expression into a sum and difference of logs. The expression given is log [ ( 2x^4(x-15)^3) / (12 sqrt (x^4-16) ].
  • Participants discuss the initial attempts to apply logarithmic properties, such as the quotient rule and product rule. There is a focus on ensuring clarity in notation and the correct application of logarithmic identities.
Some participants are questioning the clarity of the original expression and the notation used. Others are exploring how to properly apply logarithmic properties to expand the expression fully. There is a recognition that further steps are needed to achieve complete expansion.
There are mentions of potential misunderstandings regarding the use of parentheses and the representation of exponents. Participants are also noting the importance of clarity in mathematical expressions to avoid confusion.
lolilovepie
log 2x^4(x-15)^3 - log 12 sqrt (x^4-16)
3 log 2x^4(x-15) - 1/2log 12 (x^4-16)
Some clarification, please. The numerator of what you wrote is
2x4 * (x - 15)3.
If that isn't what you meant, please use parentheses or brackets to make it clearer.
3 log 2x^4(x-15) - 1/3log 12 (x^4-16)
Some parentheses would make this more readable, as would the inclusion of = for things that are equal.
Also, sqrt(x) = x1/2, not x1/3.
2x4 * (x - 15)3.
1) yeah, that's what i meant to say, but i didn't know how to do the exponents
2) ok okay thanks! did I solve the problem right because I'm not very sure :\
Starting here --
log [ ( 2x^4 * (x-15)^3) / (12 sqrt (x^4-16) ]
= log [ 2x^4 * (x-15)^3] - log[12 * (x^4-16)^(1/2)]
Can you continue?
Notice that I added * to indicate multiplication. I think that's what you intended, but am not sure.
There are some properties of logs that you either don't know or aren't using, such as log(AB) = log(A) + log(B), assuming both A and B are positive.
Mark44 said:
Starting here --
Can you continue?
after continuing would it be:
[log 2x^4 + log (x-15)^3] - [log 12 + log (x^4-16)^1/2]
and then use the power rule?
[4 log 2x + 3 log (x-15)] - [log 12 + 1/2 log (x^4-16)]
It's still not completely expanded.
  • · Replies 17 ·
  • · Replies 39 ·
  • · Replies 21 ·
