Complex Analysis: Liouville's Theorem
Liouville's Theorem asserts that if an entire function f = u + iv has a bounded real part u, then f must be constant. The discussion explores the proof of this theorem, emphasizing that if u is bounded by a constant N, then choosing M = N + 1 ensures that the function g(z) = e^{f(z)} remains bounded. Consequently, since g is constant, it follows that f is also constant. The conversation highlights the importance of understanding the implications of boundedness in complex analysis.
  • Understanding of complex functions and their properties
  • Familiarity with Liouville's Theorem in complex analysis
  • Knowledge of bounded functions and limits
  • Basic principles of exponential functions in complex analysis
  • Study the implications of Liouville's Theorem in various contexts of complex analysis
  • Learn about the properties of entire functions and their applications
  • Explore the relationship between boundedness and continuity in complex functions
  • Investigate the role of the exponential function in complex analysis
Students and professionals in mathematics, particularly those focusing on complex analysis, as well as educators teaching advanced calculus or complex function theory.
tarheelborn
Let f=u+iv be an entire function. Prove that if u is bounded, then f is constant.
Liouville's Theorem states that the only bounded entire functions are the constant functions on \mathbb{C}
I know that if u is bounded, then the real part of the function is bounded, obviously. I need a function that is bounded for both the real and imaginary parts when just the real part is bounded and I am not sure how to find that...
Think about g=1/(M-f) where M is real. How can you pick a value for M that will make g bounded?
I don't see how to do that.
What is |g| in terms of u, v and M?
Is this what you mean?
|g|=\frac{(M-u)^2}{((M-u)^2+v^2)^2}+\frac{v^2}{((M-u)^2+v^2)^2}
That's actually |g|^2. So simplify it and take the square root. Yes, that's basically what I mean.
Oops, got carried away in my LaTeX! Yes, I did mean the square root of that... Let me see if I can get anywhere from there! Thank you.
OK, so now that I have g bounded, it follows that f is bounded since \frac{1}{M-f}\neq 0. Then it follows from Liouville's Theorem that f is constant, right?
No, you are jumping to conclusions. |g|=1/sqrt((M-u)^2+v^2) is only going to be large if (M-u)^2 and v^2 are small. You can't do much about v^2. But you can make sure (M-u)^2 isn't small. Use that u is bounded. Tell me what 'bounded' means.
OK... Bounded just means that it has a limit, right?
A 'limit' in what sense? u is bounded if there is a constant N such that -N<u<N.
Well, to make sure (M-u)^2 isn't small, could we let (m-u)^2 \geq max (M,1) where M is the bound for u? This is remotely, and I mean VERY remotely, similar to an example we did in class, so I think it might be in the right direction.
Oops, that should be (M-u)^2 \geq max(M,1) ...
I'm not sure you are seeing how simple it is. If -N<u<N then what happens if you pick M=N+1??
I actually ended up starting over and going a completely different route, as follows:
Let g(z) = e^{f(z)}, which is also entire, by assumption. We will apply Liouville’s theorem to g.
|g(z)| = e^{u+iv} = e^u*|e^{iv}|= e^u
because |e^{iv}| = 1 for all z = x+iy. Since u is bounded, say u ≤ M, M \in \mathbb{R}, and e^u is strictly increasing, we have |g(z)|\leq e^M which implies that g is constant. It follows that f is also constant. \blacksquare
That works too. You do need to deal with the minor detail of showing that e^f(z) is constant implies f(z) is constant, since the exponential function isn't 1-1. The other approach would have shown for g=1/((N+1)-f) that |g|<=1 so g is constant and nonzero. Then you can just solve for f.
Thank you so much! Your direction caused me to think enough to go in the other direction. I really appreciate that!
Very welcome.
  • · Replies 27 ·
  • · Replies 17 ·
