Complex numbers: show that (a^b)^c has more values than a^(bc)
18 replies · 6K views · last reply
applestrudle
Show that (a^b)^c can have more values than a^(bc)
Use [(-i)^(2+i)]^(2-i) and (-i)^5 or (i^i)^i and i^-1 to show this.
I'm writing out the second one as the first one is long:
i^i = e^ilni
lni = i ([itex]\pi[/itex] /2 ± k2[itex]\pi[/itex])
so then
i^i = e^(=[itex]\pi[/itex]/2 ±k2[itex]\pi[/itex])
(i^i)^i = e^i([itex]\pi[/itex]/2 ± k2[itex]\pi[/itex])
as e^(±ik2[itex]\pi[/itex]) = 1
you get (i^i)^i = e^i [itex]\pi[/itex]/2
which is one value only (equal to i^-1 which is -i)
this is not what the question suggests
:confused:
please help!
I don't see why you calculated ##(i^i)^i##. The question in the OP asks you to calculate something entirely different.
It does? How?
Applestrudle, I can't see a flaw in what you did. i tried the other pair of expressions and also drew a blank.
haruspex said:
It does? How?
I thought is was a strange question. Just to confirm, for complex numbers the same laws for real numbers for exponents holds right? so for complex a,b,c (a^bc) = (a^b)^b ?
Neglecting the typo, (a^b)^c can have more ambiguity as it can depend more on the choice of the branch for the logarithm.
$$(-i)^{2+i} = exp\left((2+i)(-i \frac{\pi}{2} + 2k \pi i)\right)$$
$$\left((-i)^{2+i}\right)^{2-i} = exp\left((2-i)((2+i)(-i \frac{\pi}{2} + 2k \pi i) +{\color{red}{2l \pi i}})\right) $$
The red part should give additional solutions.
(i^i)^i = e^i(π/2 ± k2π)
Same here:
(i^i)^i = e^i(π/2 ± k2π ± l 2 π i[/color] )
I assume you meant (ab)c = abc. That identity is valid only for positive real a and real b and c. The ultimate point of this exercise is to show that this identity no longer holds for complex a, b, and c.
Another one to watch out for is the identity (ab)c = acbc. This, too, is no longer valid for complex a, b, and c.
i swear you can't do that?
mfb said:
Sure you can?
oh yeah because e is real, I'm new to this sorry.
what if a and b are real but c is complex?
For (ab)c = acbc if a and b are real but c is complex would it still hold?
No. That identity is valid if a and b are non-negative and c is real. All bets are off otherwise.
are you sure you don't mean a and b are real and c in non-negative?
No. I meant what I wrote. Try a=b=-1 and c=1/2. It doesn't work. (ab)1/2 is not equal to a1/2b1/2.
How does the red part come into play $$2l\pi i$$?
$$((-i)^{(2+i)})^{(2-i)} = e^{((2-i)((2+i)(-i\pi/2 + 2k\pi i) +2l\pi i))}$$
Isn't that what the i2kpi is for? Why can you add the second i2lpi when raise it to a complex number?
