Calculate Compound Interest: Easy Step-by-Step Guide | Calculator Tips
The discussion centers on calculating compound interest using the formula I = P((1 + R)^n - 1). A user named Shifty incorrectly calculated the interest on a £500 loan at a 12% annual interest rate compounded quarterly over 2 years. The correct calculation involves determining n as 8 (quarters) and R as 3% (per quarter), leading to an interest amount of £133.38. The confusion arose from misinterpreting the formula, which resulted in an incorrect figure of £614.90.
  • Understanding of the compound interest formula I = P((1 + R)^n - 1)
  • Basic knowledge of principal, interest rate, and compounding periods
  • Familiarity with calculator operations for exponentiation
  • Ability to interpret mathematical expressions and use brackets correctly
  • Study the principles of compound interest calculations
  • Practice using financial calculators for compound interest scenarios
  • Learn about different compounding frequencies and their effects on interest
  • Explore financial mathematics resources for deeper understanding
Students learning financial mathematics, individuals seeking to understand compound interest calculations, and anyone involved in personal finance or loan management.
logicandtruth
Hi new to the forum and would like to improve my level of maths. I am working through a text but need some help with a compound interest question.
the formula to find compound interest is I = P (1 + R)n–1.
P= principal sum
R= interest rate
n= number of periods for which interest is calculated
John borrows £500 over 2 years from a building society at a rate of 12% per annum compounded
quarterly. How much interest will Shifty have to pay at the end of the 2-year loan?
If £500 is loaned for 2 years at a rate of 12% per annum, compounded quarterly, the
calculations need to be made on a quarterly basis. So the value of n will be 4 (quarters) × 2 (years)
= 8, and the value of r will be 12⁄4 = 3% (per quarter).
According to the question the answer in book is I = 500(1.03)8–1 = £133.38.
Now my issue is when i try to do this with my calculator i get the figure 614.9
I am not sure what I am doing wrong. There are other practice questions, but I want to be sure I am following the correct stages on the calculator before I attempt these. I am using this calculator model View attachment 6280
Any advice would be much appreciated
You are misunderstanding the formula, "I = P (1 + R)n–1".
To get 614.9 you must have interpreted it as I= P(1+ R)^{n-1}:
500(1+ .03)^7= 500(1.03)^7= 500(1.29)= 614.9
But it is I= P((1+ R)^n- 1):
500((1+ .03)^8- 1)= 500(1.03^8- 1)= 500(1.2667- 1)= 500(0.267)= 133.38.
P(1+ R)^n is the amount, both initial amount and interest, that must be repaid. The -1, which, after multiplying by P is -P subtracts off the initial amount to leave interest only.
Thank you so much HallsofIvy for your prompt reply I suspected it was something to do with my use of brackets. Its just something I need to improve on. Apologies for late response and thanks again.
