Compressor driven by an electromagnet
6 replies · 1K views
Guillem_dlc
The device shown in figure 1 is a compressor driven by an electromagnet. When the piston is in position 1 it sucks in nitrogen at ##p_1=101300\, \textrm{Pa}## and ##T_1=20\, \textrm{ºC}##.
Determine what is the pressure, at ##\textrm{kPa}##, when the piston reaches position 2 and the gas exits through the exhaust valve, assuming the process is isothermal (the valves are not represented in the figure). Other data: ##\bar{M}_N=28\, \textrm{kg}/\textrm{kmol}##; ##R=8314\, \textrm{J}/(\textrm{kmolK})##; ##D_1=35\, \textrm{mm}##; ##D_2=20\, \textrm{mm}##; ##L=40\, \textrm{mm}##; ##l=15\, \textrm{mm}##. See also the other figures. The second figure represents the stroke volume ##V_A## and the exhaust volume ##V_B##. And the third figure represents the volume of a truncated cone.
Solution: ##p_2=261,692\, \textrm{kPa}##
Volumes formulas, ##\rho =\dfrac{p}{R^2T}##
Figures:
Attempt at a Solution:
$$L=0,015\, \textrm{m}\qquad R_2=0,01\, \textrm{m}$$
$$R_1-R_2=R_D=0,0075\, \textrm{m}$$
$$L=0,04$$
$$\rho_1=\dfrac{p_1}{R^2T_1}=\dfrac{p_1\bar{M}}{RT_1}=1,164\, \textrm{kg}/\textrm{m}^3$$
Calculate total volume ##V_A+V_B##:
$$V_B=\pi \cdot R_2^2\cdot L=4,712\cdot 10^{-6}\, \textrm{m}^3$$
$$V_A=\dfrac{\pi L(R_1^2+R_1R_2+R_2^2)}{3}=24,347\cdot 10^{-6}\, \textrm{m}^3$$
$$\rightarrow m=\rho_1 (V_A+V_B)$$
The piston then reaches position 2.
$$\rho_2=\dfrac{m}{V_B}=\dfrac{\rho_1 (V_A+V_B)}{V_B}=7,178\, \textrm{kg}/\textrm{m}^3$$I have done this and I don't know how to continue.
According to the solution value, the compressor increases the pressure of nitrogen 2583 times, which is evidently impossible for this problem.
Could you verify the given data, @Guillem_dlc ?
What do you mean if they are correct? What the statement gives?
Lnewqban said:
Yes, it seems to be an error in the provided information.
Well, maybe, I don't know
I got similar value to the one calculated by @Chestermiller above, which seems much more reasonable than the supposed solution of 261 692 kPa.
That is the number we would like you to verify, if possible.
