Compute Mean Square Error (MSE) for a Problem
  • Context: Undergrad
  • Thread starter Thread starter kasraa
    Error Mean Square
The correct method to compute Mean Square Error (MSE) when estimating a variable, such as the position of an object affected by Gaussian noise, is to use the formula (1) \(\frac{1}{N} \sum_{i=1}^{N} (x_{true} - x_i)^2\). This approach accounts for the individual errors of each trial, ensuring accurate variance estimation. In contrast, formula (2) \((x_{true} - (\frac{1}{N} \sum_{i=1}^{N} x_i))^2\) can misleadingly suggest low variance despite significant fluctuations in the sample set. Therefore, using the first formula is essential for reliable MSE computation.
  • Understanding of Mean Square Error (MSE) calculation
  • Familiarity with Gaussian noise and its implications in estimation
  • Basic knowledge of statistical sampling techniques
  • Ability to perform mathematical summation and averaging
  • Research advanced statistical methods for error estimation
  • Explore the implications of Gaussian noise in data analysis
  • Learn about variance and standard deviation calculations in statistics
  • Investigate Monte Carlo simulations for robust estimation techniques
Data scientists, statisticians, and machine learning practitioners who need to accurately compute error metrics in predictive modeling and estimation tasks.
kasraa
Hi all,
I want to compute mean square error (MSE) for a problem but I'm not sure if I'm doing it right.
Suppose that I want to estimate a variable (e.g. the position of an object) like x. The estimation process depends on the realizations of some specific random variables (i.e. Gaussian noises). In order to get accurate results, I know that I have to perform the estimation process N times with different seeds (i.e. different realizations of noises), right?
Lets show the output (the estimated position) of the i'th trial with x_i.
So I have x_1,...,x_N. Assume that we have access to the true value of x which is showed by x_(true).
How should I compute the MSE?
(1) [tex]\frac{1}{N} \sum_{i=1}^{N} (x_{true} - x_i)^2[/tex]
or
(2) [tex](x_{true} - (\frac{1}{N} \sum_{i=1}^{N} x_i))^2[/tex]
Many thanks.
Equation (1) is the correct formula. One problem with equation (2), which indicates how wrong it can be, is that you could have a sample set with an average equal to the true mean, but with wildly fluctuating terms, leading to zero as your variance estimate.
Thanks for your help.
  • · Replies 37 ·
  • · Replies 18 ·
