Concept for a repeat-reset rat trap
  • Thread starter Thread starter kahakura
    Concept
The discussion centers on designing a repeat-reset rat trap that can catch multiple rats without manual resetting. The proposed concepts include using a 4-spoke paddle wheel mechanism with a fixed magnet to hold the plank in position and a battery-operated zapper strip that activates when a rat crosses the plank. The simplicity of the design is emphasized, with suggestions for adding weight to the plank for automatic resetting. The conversation concludes with a consensus on the effectiveness of these ideas for creating a more efficient rat trap.
  • Understanding of mechanical design principles
  • Familiarity with basic electronics for zapper integration
  • Knowledge of animal behavior, particularly regarding rats
  • Experience with DIY projects or trap construction
  • Research mechanical design for automatic reset mechanisms
  • Explore battery-operated zapper technology for pest control
  • Investigate animal behavior to optimize trap effectiveness
  • Learn about materials suitable for constructing durable traps
Inventors, pest control enthusiasts, and DIY hobbyists looking to improve rodent trapping efficiency and design innovative solutions for repeat-reset traps.
kahakura
TL;DR
I have a rat trap that catches only one rat. Then the trap must be reset. I need ideas how to progress the concept of automatic reset so I can catch multiple rats in one night.
I have a been using a very efficient rat trap. I catch many rats in it as it appeals to their curiosity about smells and ignorance about magnets.
It is a walk-the plank rat trap.
There are more than 30 rat trap ideas but this one is good because of its simplicity.
I got my idea from this man's youtube
I prefer it to automativcally reset after catching a rat. I want it to be a repeater rat trap.
I have 2 thoughts of how to do this.
1. Use a 4 spoke paddle wheel as the plank. A fixed magnet on the wall draws the nearest paddle to hold it in position. This complicates a nice simple trap. Still, it means each paddle acts as a plank when in horozontal position.
2. Combining the plank with a battery operated zapper strip. This still complicates a simple trap.
A rat walking across the fixed plank bridges two metal strips and jumps forward off the fixed plank.
By nature, they rats jump forward, not backward, when zapped.
Example of you tube using a zapper
Example of repeater trap.
Can you help me design a concept for the most simple, repeat rat trap, over a large drum of water?
kahakura said:
Summary:: I have a rat trap that catches only one rat. Then the trap must be reset. I need ideas how to progress the concept of automatic reset so I can catch multiple rats in one night.
Sure, get a cat. Simple.
or a flute as in the Pied Piper of Hamlin.
  • Haha
Likes berkeman
Put some weight at the back end of the tilt board so it falls back to the horizontal position when the rat falls off.
Cheers,
Tom
p.s. Oh... just stumbled across this:
@kahakura , what a shame you focus on rats.
"Wanted: A Better Mousetrap"
would have been one of the best PF thread titles ever. :smile:
  • Haha
Likes berkeman
Thanks Tom,
Thanks for this helpful response.
It is a most simple solution, just as I had hoped.
I will adjust my trap to function like this one.
I'm not looking for any further solution as this seems to be a final fix.
Cheers.
Likes berkeman
I have encountered a vertically oriented hydraulic cylinder that is designed to actuate and slice heavy cabling into sections with a blade. The cylinder is quite small (around 1.5 inches in diameter) and has an equally small stroke. The cylinder is single acting (i.e. it is pressurized from the bottom, and vented to atmosphere with a spring return, roughly 200lbs of force on the spring). The system operates at roughly 2500 psi. Interestingly, the cylinder has a pin that passes through its...
28K
