Conics - How to identify figures in the plane?
  • Thread starter Thread starter José Ricardo
    Conics Plane
The discussion revolves around identifying the conic section represented by the equation x² + y² - 3x = 0. Participants confirm that it is a circle but emphasize the need to correctly find the center and radius by completing the square. The correct form of the equation should be (x - 3/2)² + y² = (3/2)², indicating a center at (3/2, 0) and a radius of 3/2. There are clarifications regarding the importance of matching coefficients when transforming the equation. The conversation concludes with a participant successfully solving the problem and sharing resources for further learning.
José Ricardo
Identify the following figures in the plane, saying if they are circles, ellipses, hyperboles or parabolas and giving their centers, rays, foci, and guidelines as the case may be:
x² + y² - 3x = 0
x² + y² - 3x = 0
x(x - 3) + y² = 0
c = (3,0)
(x-3)² + y² = 0
(3-3)² + y² -3 = 0
y = 0
x² + 0² - 3x = 0
x(x-3) = 0
x = 3
y = 0
It's a circle, the two square letters are round perfectly.
I would like you to know my errors.
x² + y² - 3x = 0
x² + y² - 3x = 0
x(x - 3) + y² = 0
c = (3,0)
(x-3)² + y² = 0
(3-3)² + y² -3 = 0
y = 0
x² + 0² - 3x = 0
x(x-3) = 0
x = 3
y = 0
You are correct that it is a circle. You have not correctly found the center. For a circle, you should also find the radius. To do this, put the equation of the circle in this form:
##(x-a)^2 +(y-b)^2 = r^2##
This expresses the relationship that each point ##(x,y)## on the circle is a distance ##r## from the center ##(a,b)##.
Likes José Ricardo
From what I understand, you calculate points where the curve intersects with the x-axis.
This is of course not sufficient. If you want to show it is a circle, then show you can write it in the form
##(x-x_0)^2 + (y-y_0)^2 = r^2##
Hint: complete the square with respect to ##y##
Likes José Ricardo
x(x - 3) + y² = 0
(x-3)² + y² = 0
Your first mistake is this step: ##(x-3)^2 \ne x(x-3)##.
Likes José Ricardo
(x - 3)² + (y - 0)² = 0
Thanks a lot, Vela!
That can't be correct. A circle has a strictly positive radius.
Moreover, ##(x-3)^2 + (y-0)^2 = x^2 + 9 - 6x + y^2## is not what you were given.
Likes José Ricardo
If you multiply out ##(x-3)(x-3)##, do you get ##x^2-3x##?
Likes José Ricardo
Did I hit now?
Ahhh... Thanks, Nich!
My professor said that the equation doesn't need to do like that in the second member. So he is wrong? [thinking]
Folks,
I'm going to the college right now. I'll give you the solution in the night or even in the college if I access the computers from there.
I don't know exactly what you mean, but I just meant that if you expand whar you wrote down, you don't get what you started with, so it couldn't be correct.
Here's a plan. Take ##
and multiply out ##(x-a)^2## and ##(x-b)^2##. To get a polynomial in x and y: ##x^2 + sx + t + y^2 + uy + v = r^2##. Then set the coefficient of ##x## (##u =## ?) in this equation with coefficient of ##x## in your circle equation and solve for ##a##. Then figure out what ##r## needs to be to make the constant term (##t + v - r^2##) equal to zero as it is in your circle equation.
Edit: In line with @Math_QED's comment, also make sure that all of the other coefficients match between the two equations.
I wouldn't recommend this approach, as initially it isn't given that the curve is a circle.
True. On the other hand, if it gives a value for the center and gives a positive value for ##r^2##, then it proves that the curve is a circle.
Or a zero radius, for a so-called degenerate circle that consists of a single point. We can also have degenerate ellipses and degenerate hyperbolas, the latter of which consist of two lines.
x² + y² - 3x = 0
x² + y² - 3x = 0
In post #3 Math_QED gave the hint to complete the square with respect to ##y##. I think he meant with respect to ##x##. That should be your first step, and not doing that is what everyone is hinting at is causing your mistakes.
Circle: ~x² + ~y² = R²
(x² - 3)² x= x² - 6x +9
~y = y; x: x - 3, c = (3,0)
(x - 3)² + y² → x = 3
I think now it's right!
x² + y² - 3x = 0
x² + y² - 3x = 0
x(x - 3) + y² = 0
c = (3,0)
(x-3)² + y² = 0
(3-3)² + y² -3 = 0
y = 0
x² + 0² - 3x = 0
x(x-3) = 0
x = 3
y = 0
CIRCLE; because both x and y are to exponent 2, possibly including one or both of the variables to exponent 1. AND coefficient on the exponent-two variables is 1 each. Nothing more is needed for identifying the conic section shape.
Likes José Ricardo
Symboli,
I restated, am I right now? It seems that gave the same result. Hm...
Okay, I was wrong. It might be a degenerate circle.
x^2-3x+y^2=0
x^2-3x+(3/2)^2+y^2=(3/2)^2
(x-3/2)^2+y^2=(3/2)^2
So I was correct the FIRST time. The shape IS a circle.
Center is ( 3/2, 0 ) and the radius is 3/2.
Likes José Ricardo
x^2-3x+y^2=0
@symbolipoint,
Why 3/2 and not 3? I didn't understand.
José Ricardo said:
@symbolipoint,
I added the term to "complete the square" to both sides of the equation. Search for your lessons about how to and why, to complete-the-square. The method allows for finding a factorization within an equation to obtain (x-a)^2, and / or (y-b)^2. Too many lessons about this are already available, in your textbook/s, in some YouTube videos, and other places online findable through internet online searches. Tell me if you need reference made to one or two of them.
Likes José Ricardo
Ahhhh, now I understood, factoration... And yes, I want video lessons from Youtube. Do you know any video that explanate conics doing look-a-like exercises like that in this topic that I posted?
Done! See your private messages.
(x-a)2 = x2-2ax+a2
Right?
So you want to make x² - 3x of the above form, and it is missing the constant term on the end, you need to add that to both sides.
(In case anyone is still interested in this problem.)
Likes José Ricardo
qspeechc said:
(x-a)2 = x2-2ax+a2
Right?
Thanks a lot, Vertigo. I already solved it.
Yes, I know, I wrote that for the benefit of anyone else who may be interested in this problem, because it's a standard problem with the standard solution I wrote above. I only answered in this thread after reading all the huffing and puffing (no offence, happens to all of us).
