Is Contact Force Responsible for Molecular Bending in Objects?
Contact force does cause molecular bending in objects, such as a book on a table, where the weight of the book leads to deformation of both the table and the book. During collisions, both objects experience compression, which can be classified as either elastic or inelastic depending on the nature of the collision. The impulse force contributes to surface deformation, while the reaction force acts on the opposing surface, but both forces are fundamentally equal per Newton's third law. The relationship between force and deformation is quantitatively defined in physics, indicating that deformation occurs only when forces are present. Ultimately, the discussion emphasizes the interconnectedness of forces and deformation in physical interactions.
tonyjk
Hello,
When we have 2 bodies in contact with each other, for example a book lying on the surface of a table. The table's molecules bend a little bit because of the weight of the book thus producing the contact force. My question is this contact force acting on the book does also bend the molecules of the book?
Thanks.
Only of you consider the "bending" of molecules as a metaphoric expression. :smile:
Hello Again,
During collision is there any compression of both objects? if yes, the collision is considered as elastic or non elastic ?
Thank you
tonyjk said:
Hello Again,
Thank you
Yes, there is compression (deformation) for both elastic and plastic collisions.
Likes tonyjk
Is the impulse force makes the deformation of the surface and the reaction force makes it on the second surface?
That's an irrelevant disctinction. Both forces in Newtons 3rd Law are on the same footing, and the choice which surface ist 1st and which 2nd is arbitary.
But do these forces make the deformation?
The forces are quantitatively related to the amount of deformation.
Ok but the forces do not deform the surfaces?
If there is deformation, then there are forces. And vice versa. Physics tells you how they are related quantitatively. The rest is philosophy.
Likes tonyjk
13K
