Converges absolutely, conditionally, or diverges
  • Thread starter Thread starter rcmango
6 replies · 4K views · last reply
rcmango
does this series converge absolutely, conditionally, or diverge?
what test to use for this problem: http://img525.imageshack.us/img525/2296/35297847wb1.png
not sure where to start. also n!^2 is that a p-series?
thankyou.
Argue, that for large enough n, (n+2)!/(n!)^2<1
is this a series that I could use the limit comparison test, so compare that to 1? then compare this to the original problem?
also, looks like a p-series to me.
Thanks so far.
That's pretty definitely not a p-series. Such a series would simply use n raised to a power, rather than n!
Have you had the Ratio Test yet? That's really the most effective technique on a general term of this sort. Also, if you succeed in showing that this series converges absolutely (since it contains no alternating term), you'll be done. (Ah, but perhaps I've said too much...)
(Hmm, if you have only gotten to the comparison tests, you'd need to use a ratio bigger than the general term that you know will give a convergent series. You could make the denominator smaller by looking at the series for just (n+2)!/[ (3^n) · n! ] , simplify that , and show that this series converges, so yours does, too.)
Note that:
[tex]\frac{(n+2)!}{(n!)^{2}}=\frac{n!}{n!}\frac{(n+1)(n+2)}{n!}=\frac{(1+\frac{1}{n})(1+\frac{2}{n})}{(n-1)!}[/tex]
What does this tell you?
Thanks for the help. I may need help simplifying the factorial in the denominator though.
i believe that now looks like 1/ (n -1)! ?
where 1/n = 0 in and 2/n = 0. so 1/ the factorial is less than one, correct?
what happened to the 3n?
thankyou.
What happened to it?
It is still there!
What you have shown is that given n>3, the terms in the series is less than 1/3^n.
What does that tell you about the series?
