Converting Numbers Between Different Bases: Is It Possible to Use Only n Digits?
  • Context: MHB
  • Thread starter Thread starter evinda
    Basis
This discussion focuses on the conversion of numbers between different bases, specifically when converting from a base $p$ to a base $q$, where $p = q^n$. It is established that each digit in the base $p$ representation can be expressed using $n$ digits in the base $q$ system. The participants explore the sufficiency of using $n$ digits for this conversion and provide examples to illustrate potential pitfalls, such as needing more digits than anticipated in certain cases. The conversation culminates in a clearer understanding of how to represent digits across these bases effectively.
  • Understanding of numeral systems and base conversions
  • Familiarity with mathematical notation and expressions
  • Knowledge of powers and their applications in number representation
  • Basic algebraic manipulation skills
  • Study the principles of base conversion in depth, focusing on examples with varying bases
  • Learn about the mathematical properties of powers and their implications in numeral systems
  • Explore the concept of digit representation in different bases, particularly in relation to padding and grouping
  • Investigate common pitfalls in base conversion and how to avoid them in mathematical proofs
Mathematicians, computer scientists, educators, and students interested in number theory and base conversions will benefit from this discussion.
evinda
MHB
Hello! (Wave)
We consider the usual representation of non-negative integers, where the digits correspond to consecutive powers of the basis in a decreasing order.
Show that at such a representation, for the conversion of a number with basis $p$ to a system with basis $q$, where $p=q^n$ and $n$ positive integer, it suffices that each digit of the number is expressed from initial system of basis $p$ to the system of basis $q$, using $n$ digits of the system of basis $q$.
Also the rule should be stated and it should be proved at the reverse case, i.e. when the conversion is done from the system of basis $q$ to the system of basis $p$.
Could you give me a hint how we could show this? (Thinking)
Hey evinda!
So we have a number like $p_0 + p_1\cdot p + p_2\cdot p^2 +\ldots$ yes?
And we have $p=q^n$ so that number is the same as $p_0 + p_1\cdot q^n + p_2\cdot q^{2n} +\ldots$.
That is a representation in the system with basis $q$ isn't it? 🤔
So if we needed $m$ digits to represent the number in the system with basis $p$, we can represent the number with $m$ digits in the system with basis $q$ as well. 🤔
Klaas van Aarsen said:
Hey evinda!
Yes, it is... (Nod) But how do we know that the coefficients $p_0,p_1, \dots$ are also based on the system of basis $q$ ? (Thinking)
Yes, but we need to show that $n$ digits suffice, right? 🧐
evinda said:
Yes, it is... But how do we know that the coefficients $p_0,p_1, \dots$ are also based on the system of basis $q$ ?
Didn't we just show that? :unsure:
We effectively wrote the same number with respect to the system with basis $q$, didn't we? 🤔
Could it be that's a mistake in the problem statement?
Consider for example that $p=100$ and $q=10$. So $n=2$.
We can represent the number $10203$ with respect to $p$ as $123$, and we can represent the same number with respect to $q$ as $10203$.
In this case we need $m=3$ digits to represent the number and $n=2$ digits does not suffice to represent the number. :unsure:
We efectively wrote the same number with respect to the system with basis $q$, didn't we? 🤔
Do we know that $p_0,p_1,p_2, \dots$ are also written in the system with basis $q$, since $p=q^n$ and so $p<q$ ?
We have that $\frac{10203}{100}=102 \cdot 100+3$ and so $10203=1023$ with respect to $100$ and $\frac{10203}{10}=1020 \cdot 10+3$ and so $10203=10203$ with respect to $10$, right? (Thinking)
More or less. It means that the digits with respect to $q$ are the same - except that there are $n-1$ zeroes in between each of the digits. 🤔
More accurately, we have $10203=1\cdot 100^2+2\cdot 100^1+3\cdot 100^0$ with respect to $p=100$.
And we have $10203=1\cdot 10^4+0\cdot 10^3 + 2\cdot 10^2+0\cdot 10^1 + 3\cdot 10^0$ with respect to $q=10$. 🤔
We effectively wrote the same number with respect to the system with basis $q$, didn't we? 🤔Could it be that's a mistake in the problem statement?
Is it maybe meant that each digit of the number is expressed with $n$ digits of the system $q$ ?
For example in this case $3$ is written as $03$, $2$ as $02$ and $1$ to $01=1$.
So since $p=q^n$ it means that each digit in the $p$-system corresponds to $n$ digits of the $q$-system.
But is this statement sufficient when we want to prove that for the conversion of a number from the $p$-system to the $q$-system that then it suffices that each digit of the number is expressed using $n$ digits of the $q$-system?
For the reverse case, we begin from the end and we pick consecutively $n$-digits at the $q$-system that correspond to one digit of the $p$-system. At the beginning, we might need to add 0s to get $n$ digits. Right? How could this rule be proved? (Thinking)
Ah right. That makes more sense. (Nod)
So we start with a number $p_0 + p_1 \cdot p^1 + p_2\cdot p^2 + \ldots$, which is equal to $p_0 + p_1 \cdot q^n + p_2\cdot q^{2n} + \ldots$.
We have that each $p_i$ is between $0$ and $p-1=q^n-1$.
So each of the $p_i$ can be written as an n-digit number with respect to $q$.
That is, we can write $p_i = q_{i0} + q_{i1} q^1 +\ldots + q_{i(n-1)} q^{n-1}$ with appropriate $q_{ij}$. 🤔
We can start with the general number $q_0+q_1 \cdot q^1+q_2\cdot q^2+\ldots$.
Now we can group those terms in groups of $n$, can't we? And each group corresponds to a digit with respect to $p$. 🤔
I see! (Nod)
I understand! Thank you very much! (Smirk)
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 16 ·
