Converting line element ds² using implicit derivatives with mixed terms
3 replies · 1K views
ozone
Say we have a function such that
[itex]x = uv , y = (u^2 - v^2) /2[/itex]
Hence our line element in Cartesian coordinates is.
[itex]ds^2 = dx^2 + dy^2[/itex]
Now I have two questions. I like to work on math problems algebraically if possible so I thought to convert our line element I could take the implicit derivative of both x and y.
Hence we have
[itex]dx = (du*v) + (u*dv), dy = (2u du - 2v dv)[/itex]
However if i were to square these terms out I would then have some mixed components such as [itex]4vu du dv[/itex]
I tested this technique with polar coordinates and using [itex]x = r \cos \theta, y = r \sin\theta[/itex] and I managed to come out to the proper line element.
Can someone please point me in the right direction as to what I need to do to get the proper line element?
Also I had one more question. If i wanted to find the equation of the unit circle centered at the origin in our new coordinate system can I just take the cartesian equation [itex]x^2 + y^2 = 1[/itex] , plug in our substitutions, and then solve?
You forgot the factor of 1/2 when you calculated dy.
thats true I forgot to write that down when I was making the post.. so this is the correct way to set up the line element?
Yup, and you should find with the correction the cross-term vanishes.
And to answer your other question, yes, you can just substitute for x and y into the equation for a circle and get the equivalent equation in terms of u and v. It works the way you think it should.
