Converting MIT-BIH ECG database files to MATLAB-compatible format
  • Topic: MATLAB
  • Thread starter lexy
    Matlab
6 replies · 26K views · last reply
lexy
hello,
I am working on a project of electrocardiographique (ECG) signal compression, in this way i need to download an ECG to treat it in MATLAB. The probleme that appears, is the incompatibility of ECG recording that i find in the "MIT-database ECG" with the MATLAB environement.
So i hope find some help by giving me,either an ECG recording with TEXT (.txt) format (because i know import it to MATLAB), or an advice to convert it.
Thank you.
(PS:sorry for my english!?)
i've found the solution on the web
To read a binary data file (e.g. ecg.dat) from within MATLAB, you can use the provided program rdsign212 (download ‘rdsign212.m’ and ‘rdsign212.dll’ from homepage). Copy these two files into your MATLAB working directory. To read the first 10000 samples of a 2-lead ECG (file ecg.dat) and assign the data to a variable ecg, type the following in the MATLAB command window:
ecg = rdsign212('ecg.dat',2,1,1000)
You can get the syntax for the command rdsign212 by typing ‘help rdsign212’.
hello,
I am working on a project of electrocardiograph (ECG) signal compression, i need to download an ECG in MATLAB. The probleme that appears, is the incompatibility of ECG recording that i find in the "MIT-database ECG" with the MATLAB environement.
So i need the help of converting .dat file to .txt file,and using it in matlab
Hi
Where can i find the 'program' (the m file), rdsign212.m??
i have an ECG project and want to disply on matlab
so i first did the hadware part and i get the ECG signal on osciloscope as analog signal so i want to display this signal by using matlab
what are the procedures can i do?
