Converting PV surface error to RMS wavefront error at 0.633 um
2 replies · 3K views · last reply
AaronBurr
Thank you all for any help or advice you can give.
1. Homework Statement
What is the fabrication Wavefront error (WFE) of a mirror with a PV surface error of 1 um? Express your answer in terms of RMS waves at lambda = 0.633 um
WFE=2*SFE
I know to start by calculating the WFE. I know the SFE=1um
WFE=2*1um
WFE=2um PV
I don't know how to convert PV into RMS. Everything I've read says there is no set ratio between PV and RMS measurements. But that values from 3-5 are commonly used depending on the surface error. So I'm a little confused.
Thank you again for any help you can offer.
I don't know much about optics, but to me it seems like the problem statement is missing some context.
There isn't any mention of a specific type of surface aberration, or perhaps some kind of approximation based on some assumptions you've discussed in your course?
Thank you for the response.
I feel the same way that's why I was asking. There is no mention of specific type of aberration in the question, and as far as I can tell from the reading you can use any number between 3-5 depending on the different aberration you are dealing with. I was hoping someone was familiar with optical engineering and could let me know what I'm missing. Thanks again.
