Convolution of a linear and rectangular function
4 replies · 2K views
Lindsayyyy
Hi everyone
I want to to calculate the convolution of the following two functions
[tex]h(t)=\left\{\begin{array}{ll} t, & 0 \leq t \leq 10 \\<br /> 0, & otherwise\end{array}\right.[/tex] and the function
[tex]x(t)=\left\{\begin{array}{ll} A, & 0 \leq t \leq 10 \\<br /> 0, & otherwise\end{array}\right.[/tex]
Convolution theorem
I tried to solve it, but I have problems with the constant A.
I wrote
[tex]h(t) * x(t) = \int_{0}^{10} h(\tau) *x(t-\tau) d\tau =\int_{0}^{10} \tau \cdot A d\tau[/tex]
I'm not sure about the last step, can anyone help me ?
Thanks for your help in advance
edit: actually I think the limits are wrong aswell? Because If I'd do it this way I get a number as a result and not a function. But I don't know what the limits should be then?!
Please note that the above is correct only for ##t=10##. To deal with ##A##, recognize that it simply stands for some number which does not vary with ##t## or ##\tau##, so you can slide it out of the integral just as if it were a number:
$$\int_{0}^{10} \tau \cdot A d\tau = A \int_{0}^{10} \tau d\tau$$
Yes, you're right. The integral you wrote gives you ##h*x(10)##. In general, you should expect one or both of the integration limits to depend on ##t##. You won't be able to write down a single integral which is correct for all values of ##t##. Instead you will have to consider several cases.
I highly recommend sketching plots of ##h(\tau)## and ##x(t - \tau)## as functions of ##\tau##. This will be very helpful to determine the endpoints of the integral. You should find that it makes sense to consider the following four cases:
(1) ##t < 0##
(2) ##0 \leq t \leq 10##
(3) ##10 \leq t \leq 20##
(4) ##t > 20##
Thank you for your quick reply. But I don't understand why you differ the fours different cases. I'd take t<0 0<t<10 and t>10 but why do you mention the one between 10 and 20 ?
I'll assume you have sketched the graphs of ##h(\tau)## and ##x(t - \tau)## as functions of ##\tau##. I'm too lazy to scan and attach an image, but your graphs should have the following characteristics:
  • ##h(\tau)## is nonzero between ##\tau = 0## and ##\tau = 10##
  • ##x(t - \tau)## is nonzero between ##\tau = t-10## and ##\tau = t##
Now, case (1) is when the graph of ##x(t-\tau)## is entirely to the left of ##h(\tau)##, and the nonzero portions do not overlap. This happens when the right edge of ##x(t-\tau)## comes before the left edge of ##h(\tau)##, i.e., when ##t < 0##.
Case (2) is when the left edge of ##h(\tau)## is between the left and right edges of ##x(t - \tau)##. This corresponds to the case ##0 \leq \tau \leq 10##.
Case (3) is when the left edge of ##x(t - \tau)## is between the left and right edges of ##h(\tau)##. This corresponds to the case ##10 \leq \tau \leq 20##.
Case (4) is when the left edge of ##x(t - \tau)## comes after the right edge of ##h(\tau)##. This corresponds to the case ##\tau > 20##.
Thank you very much again. I will try it tomorrow and if I have further problems I post again in this thread. Much appreciated your help.:smile:
