MHB How do I use the midpoint formula to find the coordinates of point C?
  • Thread starter Thread starter mathdad
    Coordinates Point
To find the coordinates of point C given that B(5, -3) is the midpoint of segment AC, use the midpoint formula. The formula results in two equations: (x - 1)/2 = 5 and (y + 2)/2 = -3. Solving these equations yields the values for x and y. The process confirms that the midpoint formula effectively determines the coordinates of point C. This method is essential for solving similar midpoint problems in geometry.
mathdad
The coordinates of A and B are A(-1, 2) and B(5, -3). If B is the midpoint of line segment AC, what are the coordinates of C?
I know this question is connected to the midpoint formula. If so, how do I use the formula to find the x and y coordinates of C?
Mathematics news on Phys.org
Let's label the coordinates of point $C$ as $(x,y)$...then (as you correctly surmised), the mid-point formula gives us (since $B$ is said to be the mid-point of $\overline{AC}$):
$$\left(\frac{-1+x}{2},\frac{2+y}{2}\right)=(5,-3)$$
This gives us 2 equations:
$$\frac{-1+x}{2}=5$$
$$\frac{2+y}{2}=-3$$
Solving each will give you the values of $x$ and $y$. :D
I knew this would lead to two equations. Thank you for your help.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 20 ·
