Cosmological Expansion: Estimating Present Horizon Length
The discussion focuses on calculating the present horizon length based on the distance light traveled at matter-radiation equality, denoted as L = H_{eq}^{-1}. The key parameters include z_{eq} = 3500, \Omega_m = 0.32, and the present critical density \rho_c = 3.64 \times 10^{-47} GeV^4. The proposed solution involves using the equation L = a(t) ∫ (da/a²H) and applying the scale factor to estimate L(z=0) = L_{eq} (1 + z_{eq}), resulting in a present horizon length of approximately 150 Mpc.
  • Understanding of cosmological parameters such as redshift (z) and matter density (\Omega_m).
  • Familiarity with the Friedmann equations and their application in cosmology.
  • Knowledge of critical density and its significance in the universe's expansion.
  • Proficiency in integral calculus as it applies to cosmological models.
  • Research the Friedmann equations and their implications for cosmic expansion.
  • Learn about the calculation of horizon distances in cosmology.
  • Explore the concept of scale factors and their role in the evolution of the universe.
  • Investigate the significance of matter-radiation equality in cosmological models.
Astronomers, cosmologists, and physics students interested in understanding the dynamics of cosmic expansion and the implications of horizon lengths in the universe.
Kyrios
If light traveled a distance L = H_{eq}^{-1} at M-R equality, how large does this distance expand to at present? (in Mpc)
z_{eq} = 3500
\Omega_m = 0.32 at present
\rho_c = 3.64 \times 10^{-47} GeV^4 present critical density
Not entirely certain where to begin for this one. I think it's asking for the horizon length at present, so perhaps need to use the equation
L =a(t) \int \frac{da}{a^2 H}
Since the problem quotes ##L = H_{\rm eq}^{-1}##, I suspect that what they want you to do is to compute (roughly) the present size of a region that was in causal contact at the time of matter-radiation equilibrium.
So would this be done by calculating H_{eq} at equality, and then expanding with scale factor, L(z=0) = L_{eq} (1 + z_{eq}) ?
If I do that, it gives a value a little under 150 Mpc.
This is the approach I would take - assuming that my interpretation of the problem is correct.
  • · Replies 19 ·
