Could the mass of a singularity be described as an empty set
The discussion revolves around the concept of whether the mass of a singularity can be described as an empty set, exploring the implications of this idea within the context of black holes and singularities. Participants examine the definitions and properties of mass and the empty set, as well as the nature of singularities in theoretical physics.
  • Some participants question the meaning of describing the mass of a singularity as an empty set, suggesting that mass is a physical property while the empty set is a mathematical concept.
  • Others propose that the mass of a singularity in the Schwarzschild metric is represented by the parameter M, indicating a lack of familiarity with other metrics.
  • One participant argues that an empty set implies no answer, contrasting it with the concept of zero as an answer, leading to a rephrasing of the question as whether the mass of a singularity could be undefined.
  • Another participant suggests that beyond the event horizon of a black hole, our understanding is limited, and the singularity could be conceptualized as a one-dimensional point, raising questions about the relationship between mass and gravity.
  • One contribution mentions that the density of a black hole is undefined, while the mass can be measured through the orbits of nearby stars, suggesting a practical approach to understanding black hole mass.
  • There is a discussion about the nature of point particles, such as electrons, and whether they can be considered singularities, with references to their finite mass and charge.
Participants express differing views on the relationship between mass and the empty set, with no consensus reached on whether the mass of a singularity can be defined in such terms. The discussion remains unresolved regarding the implications of these concepts.
Participants highlight the limitations of current understanding regarding singularities and the behavior of mass and gravity in extreme conditions, indicating a dependence on theoretical frameworks and definitions.
Quds Akbar
Could the mass of a singularity be described or defined as an empty set, or else what is the term to describe it (in at least one sentence).
Astronomy news on Phys.org
What would this mean? I have no idea what "the mass is an empty set" means.
Probably the best way to describe the mass of the singularity (in the Schwarzschild metric) is simply the parameter M which appears in the Schwarzschild metric. I am not familiar enough with the other metrics to give a good description.
Mass is a term describing a physical property. The empty set is a purely mathematical term. The question doesn't make much sense.
So how can I describe it's mass in one word/sentence?
"In mathematics, and more specifically set theory, the empty set is the unique set having no elements; its size or cardinality (count of elements in a set) is zero. Some axiomatic set theories ensure that the empty set exists by including an axiom of empty set; in other theories, its existence can be deduced."
An empty set means there is no answer, zero as an answer is not an empty set. Think of it as an empty box with no answer. Zero is considered an answer and so is any other number.
So your question is actually "could the mass of the singularity of a black hole be undefined?"
Colorless green ideas sleep furiously.
It could be honestly anything. Beyond the event horizon of a black hole; we have no understanding of what happens. The laws of physics are completely torn apart. The singularity could possibly be a one-dimensional point with an empty set. But then again, if it's empty, then there would be no mass, even though there is an enormous amount of gravity, correct?
The density of a black hole (well, the singularity.**) is undefined. The mass of a black hole isn't anything that exotic. It'll be the mass of whatever collapsed + whatever it has accreted - evaporation (negligible).
We can even measure the mass of black holes through looking at the orbits of nearby stars. e.g. for Sgr A* http://onlinelibrary.wiley.com/doi/10.1002/asna.200385084/pdf
You're asking the wrong question, basically.
** People calculate a "density" by taking the ratio of mass to volume of the event horizon, but I don't like that.
In a way, so yeah, somehow.
That's a good way to think about it, but I mean mathematically. Since infinity times zero has no answer(technically)
Why would it be undefined? The mass is a non-zero, non-infinite value, unlike the density, radius, and volume of the singularity,
An electron is considered a point particle, but, still has a finite mass, charge, etc. Does that mean the electron is a 'charge singularity'? I doubt anyone thinks of it that way. I am, however, curious if you could derive the size of a black hole singularity based on logic similar to that used to derive the size of an electron.
Not being top expert in this but explanation I heard is that 'naked' electron is considered point particle and its charge is infinite or 'most likely infinite' or at least 'huge' but theory assumes infinite so indeed it is a point singularity. The charge we observe is not the charge of 'naked' point electron but a result of interaction of the point charge with the surrounding vacuum which is polarized by the charge (meaning the naked charge is surrounded by the opposite screen charge) and what is seen on outside is a finite residual charge. Something similar could be with the mass.
  • · Replies 35 ·
  • · Replies 29 ·
  • · Replies 20 ·
