Couldn't the cosmological constant also have some sort of "dynamics"?
  • Context: Graduate
  • Thread starter Thread starter mad mathematician
The discussion centers around the nature of the cosmological constant and whether it should be considered a true constant or if it could exhibit dynamics influenced by spacetime. Participants explore theoretical implications and the simplicity of models in cosmology.
  • Debate/contested, Theoretical exploration, Conceptual clarification
  • Some participants question the assumption that the cosmological constant is indeed a constant, suggesting it might change with spacetime dynamics.
  • Others argue that the cosmological constant is the simplest model and that there is currently no evidence to support its variability, advocating for the use of the simplest model consistent with available evidence.
  • A participant wonders about the feasibility of developing a model where the cosmological constant changes over time.
  • Another participant notes that when the cosmological constant is treated as "dark energy," it allows for non-constant behavior, but emphasizes that models incorporating this variability often yield results equivalent to a constant when compared with observational data.
  • One participant mentions that while it is straightforward to write down a model with a varying cosmological constant, the data suggests that such a model does not provide additional predictive power compared to a constant model.
Participants express differing views on whether the cosmological constant should be treated as a true constant or if it could have dynamics. There is no consensus on this issue, as some support the constant model while others propose the possibility of variability.
Participants acknowledge the limitations of current models and the dependence on observational data, which may not support the dynamic models proposed. The discussion reflects the complexity and uncertainty surrounding the cosmological constant and its implications in cosmology.
mad mathematician
Why should we believe that the cosmological constant is indeed a constant, and not another parameter that changes with spacetime dynamics?
Obviously it would make the calculations even more intractable; but who said that life in the universe is easy?!
:oldbiggrin:
:oldeek:
Space news on Phys.org
Because a constant is the simplest model, and we have no evidence that it's not constant, so we use the simplest model that's consistent with the evidence.
I wonder how difficult it would be to to write down a model where it changes with time.
We usually call it "dark energy" when it's not assumed to be perfectly constant.
It's straightforward to write down the model; indeed doing that is an exercise in some advanced GR textbooks. The usual way is to use a scalar field.
But when you compare the model with data, you find that the field never changes, so it ends up being equivalent to a cosmological constant that is constant. Which means all the extra work you put into your model got you nothing in terms of predictive power. At least, not with the data we have now.
  • · Replies 153 ·
14K
  • · Replies 62 ·
12K
