Couple of questions about sets
  • Thread starter Thread starter setvectorgroup
    Couple Sets
The discussion focuses on the concepts of sets, elements, and subsets, specifically using the example of set A={b, {1,a},{3}, {{1,3}}, 3}. Participants confirm that the elements of set A include all objects within it, while subsets must be defined as sets themselves. The distinction between elements and subsets is clarified, emphasizing that a subset must be enclosed in curly braces. Additionally, proper subsets are discussed, highlighting that they must contain fewer elements than the original set.
  • Understanding of basic set theory concepts
  • Familiarity with set notation and terminology
  • Knowledge of elements versus subsets
  • Ability to differentiate between proper subsets and subsets
  • Study the properties of subsets in set theory
  • Learn about proper subsets and their definitions
  • Explore set operations such as union and intersection
  • Investigate the implications of set membership and containment
Students of mathematics, educators teaching set theory, and anyone seeking to clarify their understanding of sets and subsets.
setvectorgroup
I am confused with sets- just wanted some clarification.
Say, I have a set A={b, {1,a},{3}, {{1,3}}, 3}
What are the elements of set A?
What are the subsets of set A?
Are the subsets also the elements of the set A?
I think the elements of the set A are all the objects within it like b, {1,a},{3}, {{1,3}}, 3. Is that right?
The subsets of the set A are the elements(?) {1,a},{3}, {{1,3}}? Here's my confusion: I've seen a textbook show the element(?) {1,a} is a subset of set A like {{1,a}}⊂ A, rather than {1,a} ⊂ A. If that's the right notation, what's the difference between two different ways of parenthesizing?
Thanks.
welcome to pf!
hi setvectorgroup! welcome to pf! :smile:
no, for the reason you've referred to …
a subset is a set, so it must start and end with {}
inside the {}, you put all the elements of the subset
eg if you look carefully, you'll see that the two-element subset {b,3} is a subset of A
So is {b} so is {3} so is {3, {3}}, and so on … :wink:
tiny-tim said:
hi setvectorgroup! welcome to pf! :smile:no, for the reason you've referred to …a subset is a set, so it must start and end with {}
Thank You, tiny-tim.
So, if {3, {3}} is a subset...
Say, I make up a set S={1,2,3...}. Can I scoop up any collection of numbers from the set S and call it a subset? For example: T={1, 1000000000, 8} ⊂ S. Would that be right?
edit: Also, if I were to modify the set A={b, {1,a},{3}, {{1,3}}, 3} to make {1,a} ⊂ A true would I modify the set A like A={1, {1,a},{3}, {{1,3}}, a} ?
Say I make up a set S={1,2,3...}. Can I scoop up any collection of numbers from the set S and call it a subset? For example: T={1, 1000000000, 8} ⊂ S. Would that be right?
yes, exactly :smile:
yes, for {1,a} ⊂ A to be true, both 1 and a must be elements of A
({1,a} ⊂ A is the same as saying that 1 ε A and a ε A)
That was very helpful, tiny-tim.
I appreciate your help.
:cool:
$$\{1,a\} \in A$$
The set {1,a} is a member (element) of A, and
$$\{\{1,a\}\} \subset A $$
The set containing only the set {1,a} is a subset of A
Thanks, Joffan, for the additional insight.
What I wrote below might sound redundant, but I am trying to internalize all this set business:
Is the notation above just a statement that two random sets happen to share the same elements while the set A also contains more of other elements which makes the lefthand side of this relation to be the subset?
Thanks.
edit:
Am I right( at least conceptually) to visualize all this like :
{1,a} ∈ A
also
{1,a} ∈ {{1,a}}
while ( if you count the elements of each set)
{{1,a}} < A
which is
{{1,a}} ⊂ A
A subset of A doesn't have to have fewer elements than A. The set A is a subset of itself.
What's called a proper subset of A does have to contain fewer elements than A.
Thank You, vela.
Here's yet another attempt to differentiate between 'element of' and 'subset of' (also, by subset I'll mean proper subset) :smile:
Say, I got the following relations below and asked to see which ones are true, which ones- false:
2 ∈ {1,2,3}
{2} ∈ {1,2,3}
{2} ∈ {{1}, {2}}
Anything to the left of ∈ is an object. All I care about is if that object can be found in the set on the right side of ∈ in exactly the same form it's on the left side i. e.
2 ∈ {1,2,3} is true because the object- number 2- can be found in the set {1,2,3}
{2} ∈ {1,2,3} is false because there's no object- a set containing number 2- in the set {1,2,3}
{2} ∈ {{1}, {2}} is true because an object- a set containing number 2- is also in {{1}, {2}}
Also, say, I have these below and need to know if any of them are true:
2 ⊆ {1,2,3}
{2} ⊆ {1,2,3}
{2} ⊆ {{1}}, {2}}
The statements above, sort of, implicitly imply (to me) comparison between sets. Here we are concerned if all the elements in the subset are also in the superset i. e.
2 ⊆ {1,2,3} is false because the number two is not even a set to begin with.
{2} ⊆ {1,2,3} is true because the number 2 in the set {2} also happens in the set {1,2,3}
{2} ⊆ {{1}}, {2}} is false because the set {{1}}, {2}} does not contain the number 2
Am I looking at this right?
I am just paranoid something might slip by me unnoticed hence this (redundant) dissection.
You've got it :)
ArcanaNoir said:
You've got it :)
Well, I guess this does it.
Thank You, ArcanaNoir, for (hopefully) closing this thread.
  • · Replies 23 ·
