Covariance - Bernoulli Distribution
19 replies · 12K views
Scootertaj
1. Consider the random variables X,Y where X~B(1,p) and
f(y|x=0) = 1/2 0<y<2
f(y|x=1) = 1 0<y<1
Find cov(x,y)
Cov(x,y) = E(XY) - E(X)E(Y) = E[(x-E(x))(y-E(y))]
E(XY)=E[XE(Y|X)]
E(X) = p (known since it's Bernoulli, can also be proven
E(Y) = [itex]\int Y*1/2 dy[/itex] 0 to 2 + [itex]\int Y*1[/itex] 0 to 1 = 3/2
I'm not sure E(Y) is right.
If this is right, I still don't know how to solve E(XY).
Could we do cov(x,y) =∫ ∫(x-p)(y-3/2)dxdy from 0 to 1, 0 to 2 ?
Thoughts?
f(y|x=1) = 1 0<y<1
Find cov(x,y)
E(XY)=E[XE(Y|X)]
Your E(Y) is not correct. Rather than inputtting the coniditional distributions to start, try writing the fromula for E(Y) and work from that to see where the conditional distributions can be used.
Thoughts?
Ya I thought so.
Well, E(Y) = ∫y*f(y)dy = ∫y*(∫f(x,y)dx)dy or = ∫y*f(x,y)*f(x|y)dy
But, I can't see how to use f(y|x=0) and f(y|x=1)
We do know that f(x) = px(1-p)1-x
though equivalent, the discrete veiw point for the probability mass function may be simpler to envisage here:
f(x) = p, if x=1
f(x) = (1-p), if x=0
f(x) = 0, otherwise
Now the expectation of a function of x, say g(x) will be:
[tex]E[g(x)] = \sum_{x_i} g(x_i)f(x_i) = pg(1)+(1-p)g(0)[/tex]
If x were continuously distributed, then the marginal distribution for Y is given by
[tex]f_Y(y) = \int f_{X,Y}(x,y)dx =\int f_{Y}(y|X=x)f_X(x)dx[/tex]
As x is a discrete variable, write the marginal distribution of Y in terms of the discrete possibilties for x, and the probabilites p? It may help to think of the integrand above as a function of x...
f(x) = p, if x=1
f(x) = 0, otherwise
So are you saying Y is g(x). But, we know f(y|x=0) and f(y|x=1) but do we know g(1), g(0)?
I tried thinking of it as a discrete, but couldn't we just use
since we would get [tex]\int_0^2 1/2*1*(1-p)dx[/tex] + [tex]\int_0^1 (1*p)dx[/tex] since f(x) = px(1-p)1-x
Sorry, I'm just struggling to understand how to use the conditional pdf in this case.
You cannot integrate over x because X iis a discrete random variable and so does not have a probability density.
You wrote the formula E(XY)=E[XE(Y|X)] in your original post. Do you understand what it MEANS? Can you write it out explicitly in terms of the possible values of X and their probabilities? Figuring out how to do that is Step 1 in the solution (or, at least, Step 1 in one approach to the solution).
RGV
This is where I am now:
f(y|x=0) = 1/2 for 0<y<2 and f(y|x=1) = 1 0<y<1--> uniform distribution --> E(Y|x=0) = 1 ; E(Y|x=1) = 1/2
Also, E(Y) = E(Y|x=0)P(x=0) + E(Y|x=1)P(x=1) = 1-p/2
So, P(x=0,y) = (1-p)/3 for any y=0,1,2
P(x=1,y) = 1/2 for y=0,1 and 0 for y=2
Then,
[tex]cov(x,y) = \sum_{y=0}^2 \sum_{x=0}^1 (x-p)(y-(1-p/2))P(x,y) = \frac{p(p-1)}{2}[/tex]
Is this right?
Then,
Is this right?
Yes, it's OK. But, an easier way would be to compute E(XY) = P(X=0)*E(XY|X=0) + P(X=1)*E(XY|X=1) and to use Cov(X,Y) = E(XY) - (EX)(EY).
RGV
RGV
Hmm, I thought about that but when I was thinking about it it seemed difficult to calculate E(XY|X=0) for example. That is probably an oversight of mine, though.
But, [tex]cov(x,y) = \frac{p(p-1)}{2}[/tex] is correct?
Easiest thing in the world: E(XY|X=0) = 0 (!) E(XY|X=1) = 1*E(Y|X=1).
I do not wish to answer the last question you asked.
RGV
Doh, that was easy. It also makes a lot of sense. Both give the same answer so it's nice to see I did my summations correct.
Thanks a lot!
I think I am being really stupid here but for the E(XY) part can you write down the full working I am really stuck on it, thanks
from this help that you got what do you do, what's the final answer?
[tex]E(XY)=E(xy|x=0)P(x=0) + E(xy|x=1)P(x=1)[/tex]
yep then i get that the original equation its what to do after, am i expecting an answer in terms of p and q? so i understand that the part E(XY|X=0) = 0 (!) and that E(XY|X=1) = 1*E(Y|X=1)
so does that mean I am left with E(XY)=E(Y|X=1) ?? its from here i am stuck, sorry if I am completely missing the point!
Yes, you should get an answer in terms of p.
Just use the E(XY) formula above and recall the formula for cov(X,Y).
Cov(XY)=E(XY) - E(X)E(Y) if I am not mistaken?
sorry I am being slow but i don't understand how you get E(Y|X=1) into terms of p and q
Yes, [tex]cov(X,Y) = E(XY)-E(X)E(Y)[/tex].
Moreover, [tex]E(XY) = E(XY|X=0)P(X=0) + E(XY|X=1)P(X=1)[/tex]
Now, find P(X=0), P(X=1) (this should be easy).
But, you are asking about how to find E(Y|X=1)? Well, we have a formula for f(Y|X=1) don't we? It's a horizontal line at 1 from 0 to 1. Then, the expected value (E(Y|X=1)) should be right in the middle.
Same idea for E(Y|X=0).
ok ill give it a go now, thank you so much!
