Current from a windmill generator with 2.0 m blades
  • Thread starter Thread starter Hafid Iqbal
7 replies · 3K views
Hafid Iqbal
A 120-V generator is run by a windmill that has blades 2.0 m long. The wind, moving at 12 m/s, is slowed to 7.0 m/s after passing the windmill. The density of air is 1.29 kg/m3. If the system has no losses, what is the largest current the generator can produce?
(Hint : How much energy does the wind lose per second?)
Thank you very much...
What have you tried?
Where are you stuck?
We shouldn't try to help until we have seen that you have tried.
[itex]\Delta \ KE = -\frac{1}{2}.m.(v_2^2-v_1^2)=-\frac{1}{2}.\rho.V.(7^2-12^2)=61.275V[/itex] (V = Volume of air)
[itex]\frac{\tau}{\epsilon} = \frac{N.B.I.A}{N.B.A. \omega} = \frac{I}{ \omega } \ \rightarrow \ \tau= \frac{\epsilon.I}{\omega}=\frac{P}{\omega}[/itex]
[itex]\tau=\frac{\Delta KE}{\omega.t} \ = \ \frac{61.275V}{\omega.t}[/itex]
And I stuck from that point. Here is my problems :
1. I don't understand what is the use of blades' length
2. How to find volume of air?
3. Is it true angular speed not given?
It could be that they want you to assume that the cross sectional area of the airstream is defined by the span of the blades as they rotate.
I still can't get the answer... :(
Anyway, the book says its answer is 77 Ampere
Start with determining the volumetric rate (m3/s) at which air is passing the windmill cross section. Then turn that into mass rate by multiplying by density. What do you get?
How to find volumetric rate sir? If I multiply it by density, i wiil get mass rate...
Volume has units of m3. Cross sectional area has units of m2. Velocity has units of m/s...
